Won't get up to speed!
  • ekaser
    • 33
    I have recently the boat. I submarined it because I didn't get on the trottle. I dryed everything out and tried again. This time no submarining, but, the boat does not have any speed it just plows through the water. Every once in awhile it takes off for a couple of seconds then it just returns to plowing speed.
    I have checked all wires. Everything is stock but the prop, which is a grim racer. Diesel said it is a good one for this boat. I am using 2s Hobby People 35c lipos.
    Any suggestions?
    Thanks, Ed
    "People do not quit playing because they grow old, they grow old because they quit playing"
    Oliver Wendall Holmes
  • dana
    • Mar 2010
    • 3660
    what prop is it?
    • ekaser
      • 33
      The prop is a Grim Racer L40 x 57
      • dana
        • Mar 2010
        • 3660
        That's a good prop but needs to be balanced and sharpened really well before use.
        • dana
          • Mar 2010
          • 3660
          you could try dropping the strut down. you arent giving us enough info to help you really. who balanced and sharpened it? whats your strut depth?
          • ekaser
            • 33
            I have done that. The boat will really go for short bursts. But it won't maintain top speed. I can hear a difference in the pitch of the motor.
            • dana
              • Mar 2010
              • 3660
              Done what? All I can say is the prop needs to be done right to make it work
              • JimClark
                • 5913
                search the forum all your questions are answered previously there
                Billy Graham
                • Diesel6401
                  Memento Vivere
                  • 4391
                  Yup that's my favorite prop on that boat. Gotta admit that I am not to familar with the Hobby People lipo's.
                  * You are using 2x 2s lipos correct?
                  What is the mah rating on those?
                  - Prop properly sharpened and balanced
                  - Strut depth around 1 1/8"
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • G-UNIT
                    • 971
                    Did you check all the wires UNDER the heat shrink, you could have a bad solder joint giving you intermitent contact.
                    • dana
                      • Mar 2010
                      • 3660
                      Plain and simple, those props don't work unless it's prepped right. Period
                      • ekaser
                        • 33
                        Thanks guys I will work on your suggestions and let you know what happens.
                        • egneg
                          • 4759
                          Octura M445, strut at 15/16" neutral, and I hope the 2 x 2S are in series for a total of 4S.
                          IMPBA 20481S D-12
                          • Meleagris
                            • 1
                            I'm wondering if it is a battery problem more than the prop? My gut is that you are not getting power... Does it sound like the cutoff (stutter-bump) is kicking in to anyone else?
