2200kv drop in?
  • TheGnMan
    • May 2011
    • 61
    2200kv drop in?
    Hello Im a car guy trying to get into the boat world. I have a castle 2200kv 1/8th scale motor just sitting around can that drop right into a ul-1. Does water jacket fit and or is there anything else i need to know? Should I expect performance gains or should i just leave well enough alone and stick with stock. thxs abunch
  • LarrysDrifter
    Big Booty Daddy
    • 3278
    You can get a jacket for it here when they are in stock.
    • m4a1usr
      Fast Electric Addict
      • 2032
      The CC/Neu 1515/2200kv motor is a decent choice. A bunch are using that motor with great success. You dont need a motor that big but if you got it already then why not. It will bolt right up to the stock motor mount. The stock UL-1 cooling can will not work on that motor. You would need to buy one from OSE or similar if you wanted a cooling jacket. But you dont really need one. Even using a big prop, like a 445 or even a 545 it wont over heat that motor for the size batteries you can stuff in the hull. So dont feel like you have to water cool it.
      I run a Leopard 4074/2150 motor (close equivalent to the better CC/Neu 1515) on 4S with no heat issues. I only cool the esc just to not waste available cooling for my T180 esc.
      What I would recommend is to add a tapered block glued down under the motor to the floor pan and wire tie or something similar. The thin stock motor mount does flex using the, longer, heavier, more powerfull motor and if you add a lower wedge block with a wire tie on the end of the motor the flex is greatly reduced. Dont know if that makes sense but it keeps the flex shaft from being pulled and pushed about while the stock mount bends.
      John
      Change is the one Constant
      • TheGnMan
        • May 2011
        • 61
        Thxs John basically just get some support under the motor anyway i can. I know these motors are great i run the crap outta them in 3 of my trucks , 1 on 5cells, and never get temps breaking 125f.
        Rob
        • detox
          • 2310
          I once tried the 1515 1y 2200kv motor in my UL-1. I used the smaller m440 prop to keep boat under control. Using the m445 hull was wicked fast and loose (easy to flip). No motor support is needed. Hydra 120 did not last very long eather.
          • TheGnMan
            • May 2011
            • 61
            What do u mean by hydro 120 not lasting? Im going to use the stock esc will that be fine? Do you think the 40 x 57 prop will work on this setup? Thxs Rob
            • detox
              • 2310
              Stock esc will not work (too many amps). If the 40x57 is sharpened and thinned it will work.
              • TheGnMan
                • May 2011
                • 61
                Really the stock esc wont do it huh. Well scratch this idea for now. That blows. What esc do u recommend?
                • Diesel6401
                  Memento Vivere
                  • 4203
                  Stock esc is def a no go on that. I hydro 120 is double the rating of the stock esc and detox smoked his. A swordfish 200 would work nicely.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • TheGnMan
                    • May 2011
                    • 61
                    This might be a stuip question what about the mamba max esc that i bought in the combo with the motor. I could waterproof it and it is fan cooled or is that a no go. Its just I have one of those sitting around to. Is that idea a no go? and why if no.. please, thxs again everyone. BTW I have another thread goin with prop issues just trying to go a little faster and the prop isnt working out. Its my fault im sure ,dont know crap about boats but im trying to learn so I appreciate all and any help
                    • Chilli
                      • 3067
                      Whats the amp rating on the Mamba ESC? A boat getting pushed through the water has allot more drag than a truck rolling on a level surface or even slightly up hill. Thus boats put much more load on a motor. Propped reasonably your motor is probably pulling in the area of 120 amps. Even more when accelerating or in a sharp turn. You'll need at least a 180 amp controller to be safe.
                      Mike Chirillo
                      www.capitolrcmodelboats.com
                      • LarrysDrifter
                        Big Booty Daddy
                        • 3278
                        Mamba max is a 120 amp.
                        • detox
                          • 2310
                          The Mamba Monster may work with that motor and 4s. The small m440 will work nicely:
                          I once used that esc with a nue 1515 .5y (1500kv) and 6s in my Phil Thomas SS21.
                          • TheGnMan
                            • May 2011
                            • 61
                            Detox i dont understand you burnt the hydra with same amp rating but you had no problems with mamba setup on 6cells. So will I be safe running on 4. For now I think im just goin to run the stock prop Im having issues with the 40/57 i bought was told thats not a good choice since that was the 1st prop i ever sharpened and balanced. Is the m440 something easier to work with? Can i even run the stock nylon prop safely? thxs abunch
                            • scoota
                              FE DOWN UNDER
                              • Dec 2008
                              • 409
                              You will break the blades off the stock prop , try one of these http://www.offshoreelectrics.com/pro...od=grp-2317.45 cheep & they are balanced , here is a pic of my setup 1515 1y cc/neu & a 240 swordfish esc , runs cool & speeds in the high 50s , i have just cut up some pool noodle to wedge under the motor for the extra weight on the mount ..
                              UL1- 1515 castle/neu / 240 swordfish
                              SV27- with UL1 running gear
                              33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
