I want to put a fuego 540XL and A seaking 180 In my ul1 but dont know what size 540xl to get Can someone help me out? And is that a good combo
Ul1 question
Tags: None
How many cells or packs do you want to run? Also how fast do you want to go? If you want to stick with something stock get a 7xl but you wont be running a large prop. Also why run a 2 pole motor when you can get a 4 pole that will perform better? Look at this one, same price but 4 pole http://www.offshoreelectrics.com/pro...prod=keda-4074 Or you can get a Tacon 4074 if you dont like the Keda. But if your new to FE boats a Feigao may not be a good choice. Its a good motor. But the Keda/Tacon will perform better and for the same price.Originally posted by Mike whiting View PostI want to put a fuego 540XL and A seaking 180 In my ul1 but dont know what size 540xl to get Can someone help me out? And is that a good combo
JohnChange is the one Constant
Not really sure maybe at least up to 6s one or two packs preferably one for weight. Iam new to boats so thank you I want my boat to do about 60+ I like The keda but what Suzette do I need
[QUOTE=Mike whiting;312356]Not really sure maybe at least up to 6s one or two packs preferably one for weight. Iam new to boats so thank you I want my boat to do about 60+ I like The keda but what Suzette do I need[/QUOTE
I have been messing around with mine for a while now and i think with this boat you should stick with 4s like i have .... its plenty fast believe me
Leopard 3674 2650 kv with a swordfish 200 and the softest timing setting.
2s2s 5000 40c lipos and an m545 will get you to 60 mph keeping it on the water is the tough part
Airdams, c.o.g, turn fins, numerous props all wont make it an easy boat to stay stable for long over 60 IMO.
Its a great RTR hydro just put a prop and a decent set of bats. in it and enjoy it
http://www.hobbyking.com/hobbyking/s...dProduct=14691
I run these the nano's are always on back order it seems
Was just looking and found a 4 s 5000 40c that will fit.
Im going to run these as our class in Aus. says one lipo only
http://www.hobbyking.com/hobbyking/s...dProduct=10307
Cool do you like running deans and also what size connectors do you run to connect esc and motor
Will the deans melt and how do you run in series with bullet connectors or how do you make connections I should ask
The 5.5s are the way to go but the 3674 leopard has 4 mm connectors and its not good to mess around with the motor cables as some are actually part of the motor windings, i believe you can heat them off and resolder, but i didnt want to mess with them as there seems to be no heat dramas so i leave them alone.
Dont know about melting but they do get mighty warm and series is pretty simple positive of the first battery to esc red wire. negative of first battery to positive of second battery and the negative of the second battery to the black esc wire. Your standard ul1 is wired up this way with the deans connectors. Do a search of the o.s.e store in tips and info to be sure before you do anything, i dont wanna blow up your new lipo's for ya LOL
