ul 1 /60amp in sv27
  • CHUD
    • 497
    ul 1 /60amp in sv27
    GUY'S last year I got my sv27 in the water three times.The last time I flipped it and got the anttana wet she came in and I fixed it than dropped back in and she would crap out like it could not arm it self,Took it back out the next day same thing one lap crap out, so I payed for a used ul1/motor and 60esc with controler,I put the old 60ampand put in the hydro today and she made one pass and crapped out IS IT THE 60AMP FROM LAST YEAR THAT'S CRAP,Has anyone had this happen, When I get it in she try's to re arm,
  • dana
    • Mar 2010
    • 3570
    sounds like a radio issue
    • CHUD
      • 497
      I thought so to dana ,But I put the new radio in the hydro,and also ran the mini today with the new one,she ran fine ,I never got a lap with the hydro 2 times
      • Diesel6401
        Memento Vivere
        • 4203
        What is crap out? just shut down or stutter or intermittent?!?
        * Shot in the dark, but it could be a cap issue. Is it the older ul esc with the smaller cap or does it have the HUGE cap hanging off the end? http://www.offshoreelectrics.com/pro...od=dh-aqum7011
        If it has the smaller cap on it. Try soldering on a new one.
        - Diesel's Youtube
        - Diesel's Fleet
        • CHUD
          • 497
          wow look's like it's the old one /D/ the top one is the one I'v been useing ,never tested the other.Me and dana split a ul1 on the swopshop.So I could get the /tactic 2.4 and put it in the sv,because I thought the proboat was bad in my sv last year.And I took the other motor and put it in my hydro, I'v just been swopping the tactic controller around all three boat, And when I found out I had no other conector's for the 60amp from the one me and dana got ,I just pulled the one out my sv just to test the hydro yestureday and she just brockplain and shutdown when I got her back to the me opened her up and she rearmed ,dropped back in the water same thing,Can I change the bullet's to the other 60amp or do I need to,
          • dana
            • Mar 2010
            • 3570
            Was it the yellow ul1 we split? I don't remember.
            • CHUD
              • 497
              I think so ? you got the hull I got the/motor/tactic/@60amp speedcontrole
              • dana
                • Mar 2010
                • 3570
                No I think you're confusing me with someone else. I got a ul1 with everything in it
                • Diesel6401
                  Memento Vivere
                  • 4203
                  I would try adding an additional cap bud. Also make sure your batts are real good, nothing less then 4s lipo or the lvc will kick in.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • CHUD
                    • 497
                    Your right danaSorry bud
                    • CHUD
                      • 497
                      There 5.0 2cell/7.4 volts whats lvc /Diesel/
                      • dana
                        • Mar 2010
                        • 3570
                        I'm so confused about what the problem is here tho... Swapping stuff all over the place lol. Does the radio work in your other boats? You just have the one radio for them all right?
                          • 7277
                          lvc=low voltage cut off
                          • CHUD
                            • 497
                            Thats right dana,I was using one a proboat with my hydro and the sv but I thought it was bad ,so I got another that was a tactic 2.4 with a motor and esc all in one, and someone else got the hull,
                            • CHUD
                              • 497
                              why would that happen Doby
