installing cooling jacket in ul-1
  • silvermansteve
    • Aug 2009
    • 147
    i just purchased from ose the cooling jacket made for the ul-1. ose shipped it promptly, and it looks very good. it seems to be a very tight fit. i don't want to apply brute force and know there must be a right, best way to get it on the motor.
    can someone tell me that they believe is the correct way to install it? use a little grease maybe?
    thanks!
    steve
  • scoota
    FE DOWN UNDER
    • Dec 2008
    • 409
    You have to use some grease or a bit of thin machine oil works as well , if you dont lube the o'rings you might damage them ...
    UL1- 1515 castle/neu / 240 swordfish
    SV27- with UL1 running gear
    33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
    • LarrysDrifter
      Big Booty Daddy
      • 3278
      I rub engine oil on the can and o rings and slip the jacket on.
        • 7277
        Dish soap works well.
        • silvermansteve
          • Aug 2009
          • 147
          thanks to you all for your help and taking the time to give me this advice.
          • dasboata
            • Dec 2010
            • 3152
            I had a hard time also on a feg motor what I ended up doing is lightly sanding a radius into the sharp corner of the motor I use a 1" belt sander with 400 grit and was oh so gentle
            • Diegoboy
              Administrator
              • Mar 2007
              • 7247
              Thread moved
              • silvermansteve
                • Aug 2009
                • 147
                thanks again. i got it -- i used some of that blue aquacraft grease. didn't have to resort to grinding . . . . fits great.
