Ul1 motor problem
    • 9481
    Originally posted by longballlumber View Post
    I would make sure you remove the shrink wrap off of the connectors on the motor side. It sure sounds like a connector problem, like most have mentioned. This exact thing has happen to me several times.
    Later,
    Mike
    same thing to me, and when I resoldered all the connections I actually picked up another 2mph
      Definately solder connections. Try to move up to a larger connector. I use 5.5mm plugs at the motor.
      I'm glad you got it sorted out.
      They should start using better connector on these motors. Even the Leopard stock 4mm connectors blow away the 3.5mm ones PB or AC uses....
      • G-UNIT
        • 971
        It would be nice to pick up alittle more speed with the new connectors,
        I can't seem to exceed 45.5 right now, m445 prob 40c/50 5000mah, strut at 1" / 1 1/8 / 1 1/6
        not much change, we'll see later today when I get off work if the connectors were holding me back.
        even running 1745 3 blade, same speed.
