UL-1 air dam
  • weil0127
    • Dec 2009
    • 164
    UL-1 air dam
    I just installed my air dam from JRS innovations and this boat came alive. I was having a lot of hopping at the end of straits, but not with the air dam in place. It made this boat run better than it ever has. I didnt have to let off to settle the boat back down at top speed. Here are some pics...
    www.namba20.com
  • G-UNIT
    • 949
    should'ent it be standing up? it only looks about alittle over 1/8 inch thick, just asking because my home made one is about 1/2 inch in depth.
      • 7990
      The functional depth of the air dam should be around 1/4". All it needs to do is turbulate the air in the tunnel to reduce the lift. We've made tape air dams for many years - I first did it in 1994 and I leared about it from other FE guys. But the tape air dams fold down somewhat at speed. A solid 1/4" dam should work well. If it doesn't then add another 1/4".
      • G-UNIT
        • 949
        OK Then for s&gs i'll shorten my dam and see what happens.
        • weil0127
          • Dec 2009
          • 164
          All I know is it made the boat run better than it ever has. 1/4 might just be over kill.
          www.namba20.com
          • m4a1usr
            Fast Electric Addict
            • 2032
            What exactly did they sell you? It looks to be a solid chunk of "something"?
            Is it foam or plastic? If it works, what the heck. It did the job but its a bit different then what is commonly seen. Looks like its 1/4" thick? I did the 1/2" corner moulding plastic. Worx fine but always good to see what worx for others.
            John
            Change is the one Constant
            • weil0127
              • Dec 2009
              • 164
              It is the composite material that he makes his boat stands out of. The best way I can describe it would be the composit decking, but nothing effects it (nitro fuel/gas). It is 1/8" thick. It really doesnt need anything bigger after running it. It might just be over kill to go thicker.
              www.namba20.com
              • JPriami
                N4FOX
                • 1675
                pretty interesting idea.
                • martin
                  • 2869
                  When i raced at the tethered hydro world championships in 1985 ( ic motors) i watched the Russian world record holder stick a match stick across the bottom of his hull. These hulls are only around 2.5" wide, But because of a slight breeze across the water surface he was getting slightly to much lift at the front & holding the speed back 2 or 3 mph. After attatching the match stick as a dam he set a new world record at 135mph in the then 5cc class. Thanks.
                  • weil0127
                    • Dec 2009
                    • 164
                    Sometimes less is more
                    www.namba20.com
                      • 7990
                      What matters is what works. A match stick at 135 mph may create the same turbulence as a 1/2" dam at 40 mph. I use a drinking straw taped under the nose of my 60 mph P Sport Hydro as a dam and it works great.
                        • 7277
                        What brand of straw works the best.....
                        • martin
                          • 2869
                          What brad of straw works the best.....
                          Not the bendy ones.
