Stock setup on 40C...anyone using this?
  • Capt. Crash
    • Jan 2009
    • 301
    My Max Amps are quickly dying and they cost way too much to replace when these cheap HK packs are available now. I have some Turnigy and Zippy 5000 2s 40Cs Soft Case packs on the way....anybody ran with these yet? How does the stock esc/motor do with them? Any overheating?
  • GP73
    • 544
    Yes... like... everybody...
    • weil0127
      • Dec 2009
      • 164
      They work great. I also use the blue lipo's. Never had a problem.
      www.namba20.com
      • Gunny
        Zombie Hunter
        • Feb 2011
        • 71
        yep! all the time
        A bizarre incident in the outskirts of an American suburb. It was later revealed the disaster was caused by the T-Virus. A mutagentic toxin created by Umbrella Incorporated for use in bio-weapon experiments. Don't worry the zombies are looking for brains, you're safe.
        • DyrtyByrd
          • 146
          if they will fit go for it i use the turnigy 5000mah 2s 20-30c batts and they work great but fit tight i think with the higher c rating the batts are slightly larger but like i said as long as they fit your good you should have no overheating issues and you might get a slight boost in performance from the pack with a higher c rating as they can withstand higher amp draws
          • Capt. Crash
            • Jan 2009
            • 301
            ok...thanks guys...I just didn't know if the esc could handle the extra juice without popping a cap or melting the deans....
            • G-UNIT
              • 949
              no problems with then here, already 1 year old and running fine
              • cptcrusty1
                • Feb 2011
                • 26
                I have a pair of 30C Venom batteries, 5kmaH. They both puffed up on me, but I also think their deffective. Both batteries 1st cell won't hold juice. I just ordered a couple Rhino or Turnigy (can't remember) packs to replace them.
                • GP73
                  • 544
                  The C discharge rating of a battery is how much the battery can deliver, doesn't mean your motor/ESC/prop/hull combination is actually using it.
                  In short: larger C rating is ALWAYS a good thing, unless the battery is too big or heavy for the boat.
                  Get rid of the DEANS as soon as possible and replace battery and motor connectors with 5.5mm bullets (or bigger). It will save you time and grief in the long term.
                  • Capt. Crash
                    • Jan 2009
                    • 301
                    I agree that the 5.5mm is the way to go if your using ALL good conductors...but if, like in the case of the UL-1, your using thin 14ga motor/esc wire what difference is it really going to make?
                    • Diesel6401
                      Memento Vivere
                      • 4203
                      Venom packs of a history of failing, they can not handle the amp load of rc boating. Their not defective their just venom....
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • Kris88
                        • 2
                        Im running 40c turnigy 5000's and they work great
                        • pescador
                          • 499
                          The 6000mah Turnigy Nanotechs fit nicely in the UL-1 as well.
                          Namba District 16
                          1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
                            • 9479
                            having higher C rated packs can actually cause the system to run cooler
                            if things smoke, the setup was wrong to begin with
                            • rc2266
                              • 312
                              Never had one that didn't go bad
                              I'm married with children, you can't scare me!
