can someone help a brother out por favor?
  • dreamland s4
    • Dec 2010
    • 347
    stock motor, 120 amp seaking esc, L40x57 grim 3 blade prop, 3000mah 3s 40c lipos 22volts ( in series) = fried esc. can someone shed some light on what went wrong? the boat went 20 feet before completely shutting off dead. we checked the esc and yes it was burnt.
    Last edited by dreamland s4; 01-12-2011, 10:44 AM. Reason: im sorry guys. my bad foreal.
    If the #2 pencil is the most popular, why is it still #2?
  • Diegoboy
    • Mar 2007
    • 7443
    Which 3 blade grim prop?
    2 - 30c lipos in series, but what cell count? (2 - 4S? 2 - 2S? 2 - 8S?)
    • dreamland s4
      • Dec 2010
      • 347
      2s L40x57 prop 3s 40c (22v)
      • Diesel6401
        Memento Vivere
        • 4391
        Any binding in the drive line any where? 3000mah is a little low also, packs can't deliver a lot of amps.
        - Diesel's Youtube
        - Diesel's Fleet
        • dreamland s4
          • Dec 2010
          • 347
          i mean if i twist the prop with my fingers i can feel the poles of the motor. you understand what i mean? i think its normal. previously i ran it very smoothly with very low temps on my buddys 3500mah 20c 2s's.....as soon as we tried these new lipos, all hell broke loose. to be more specific, the fist time i launched her the collet came loose and i thought i lost my prop. so i tightened it up and on the 2nd launch she went about 30 feet then poof! silence ! how free is the prop saposed to spin when you rotate it with your fingers???
          • dreamland s4
            • Dec 2010
            • 347
            hey wait they were 40c not 30c. i apologize for that.
            • dreamland s4
              • Dec 2010
              • 347
              they were 40c not 30c im sorry for that.....
              • Diesel6401
                Memento Vivere
                • 4391
                Got ya, that's normal. Just making sure theirs no binding. You should inspect the flexshaft just to make sure nothing looks abnormal. Binding can cause a HUGE spike in amps and fry some stuff.
                - Diesel's Youtube
                - Diesel's Fleet
                • dreamland s4
                  • Dec 2010
                  • 347
                  you know what dude your right. im going to check things out and if i see something im going to take pics of it. so basically the lipos i was running shouldnt have been at fault correct?
                  • dreamland s4
                    • Dec 2010
                    • 347
                    i just got my info straight. its 3500MAH 3S 40C (22V) IN SERIES.
                    IM SO SORRY. BUT EITHER WAY, SHE SHOULD HAVE BEEN ABLE TO HANDLE THIS POWER RIGHT? OR?
                    • LarrysDrifter
                      Big Booty Daddy
                      • 3416
                      6s on the stock motor is a no no.Too much rpm.Some people have had bad luck when running an esc at it max voltage rating.This is what you did.I assume you used no external BEC or reciever pack.Id say you burned up the esc and you d be lucky if the motor didnt fry also.You did just run the motor at 45,066 rpm.Research next time instead of just throwing more voltage at parts.
                      • dreamland s4
                        • Dec 2010
                        • 347
                        your right m8! i screwed up. but as long as i finally know what my problem was i could sleep better at night.....darn! ok so 4s is max for stock ul1 motor.
