how do i fill two small drilled holes on ul1 superior transom?
  • dreamland s4
    • Dec 2010
    • 347
    guys i totally made a mistake and need to patch up 2 small drilled holes. (same size as the water inlet-outlet predrilled ones) i drilled them right next to them in fact. whats a fast easy reliable way to git her done? thanks.
    If the #2 pencil is the most popular, why is it still #2?
  • egneg
    • 4759
    Since it's a double hull plug it with wood dowel and epoxy over them.
    IMPBA 20481S D-12
    • dreamland s4
      • Dec 2010
      • 347
      hey prop master, thanks alot....hey im a real rookie here, would you mind tellin me whats a wood dowel? and where can i find that??
      • H&MWill
        • 680
        Its a wooden rod available in different diameters. Hobby shop or craft stores. Cut it to length needed.
        Many issues!!!
        • dreamland s4
          • Dec 2010
          • 347
          thank you so much. really.
          • longballlumber
            • 3417
            Most neighborhood Hardware stores will carry wooden dowl rods too...
            Ace, TrueValue, Lowes, Home Depot..... etc....
            • dreamland s4
              • Dec 2010
              • 347
              i love these type of stores.
              • dreamland s4
                • Dec 2010
                • 347
                ok so two wood dowell rods, stick them in and glue them? or lightly press them in? then grind them to flush with transom? then a rectangular piece of fiberglass?. im all ears. any better ideas on installing the rods? .i made a dumb move...its kool though. hey u guys see that hairline crack? does that mean ?
                • dreamland s4
                  • Dec 2010
                  • 347
                  i might be confusing it for somethin else. but to me it looks like a thin crack spreading. geez does this mean my hull is going to crack? hope its not uncommon. u guys have or had any of these without further issues??
                  • longballlumber
                    • 3417
                    I would drill out the holes to the proper sized wooden dowel rod. You want this to be a tighter fit rather than lose. Leave a little sticking out on either side and use some thin super glue on each end where the wood dowel meets the hull. After the glue has dried SAND (don't grind) down the extra sticking out. Lastly, I would hit the wood dowel with some more super glue. That will help seal the bare wood.
                    Later,
                    Mike
                    • dreamland s4
                      • Dec 2010
                      • 347
                      Later,
                      Mike
                      ur the man mike!!!
