new to ul1
  • Gen
    • Dec 2010
    • 130
    new to ul1
    i want to buy a ul1 and was thinkin of hoppin it up ,whats a good leopard motor i can use on 4s with a seaking 180 esc ,and what prop is good for this combo the grimracer 3 blade ??
    and can these boats go full pelt and turn and stay in the water or do the ride completly out of water ?? ..
    how do they perform with only prop upgrade ,or do they need motor upgrade too ?? ,any help appreciated
    and if you upgrade motor do you need to fix shft ect or is stock one ok with better motors ??
  • egneg
    • 4759
    Prop is all you need - Octura M445 does very well.
    IMPBA 20481S D-12
    • dreamland s4
      • Dec 2010
      • 347
      If the #2 pencil is the most popular, why is it still #2?
        • 7512
        Keep in mind that UL-1's only turn well to the right.
        • Gen
          • Dec 2010
          • 130
          so prop upgrade ,all thats required ,do you run on 4s ,5s or 6 and if esc only rated to 4s can u do just esc upgrade and run on 6s ??? and cause of the turn fin and there oval racers you can go full pelt right hand turns .....??
            • 7512
            The motor is a 4S motor....how fast are you trying to go? Low 50's is about max this hull can take before becoming a handful.
            Whats a "pelt"?
            • dreamland s4
              • Dec 2010
              • 347
              my seaking 120 esc just arrived.....im running a grim 3 blade.....i hope these ecs's are worth it! cuz they are dirt cheap!!!!
              • egneg
                • 4759
                The Turnigy/Seakings are good but a cap bank sure helps.
                IMPBA 20481S D-12
                • Gen
                  • Dec 2010
                  • 130
                  [QUOTE=Doby;268301]The motor is a 4S motor....how fast are you trying to go? Low 50's is about max this hull can take before becoming a handful.
                  Whats a "pelt"?[/QUOT
                  pelt is just a saying full pelt same as full throttle full gas ,full stick all i mean is with esc at maximum full speed ..
                  • slowroll
                    • 10
                    A STOCK ..motor and speed controller and a Prather 215 / or x642 and a pair of 5000mh 30-40c batteries and hold on!!!!! youre going for a ride.......HAVE FUN!!
