Lipos UL-1 and prop
  • racer66
    • 68
    I will check out that low voltage cut off for the lipos. I went on line today to Kentic Racing to order some parts, but they r having trouble with the online ordering.
    Are you guys setting times? Like 4 min or so? And r u useing an alarm on the radio or some other beeping alarm to warn you that time is up?
    What should be my first order of business when I get my UL-1? Change the shaft to the .150 Octura and replace the nylon tubing? Thinking about a after market coupler and a bearing that will slide on the motor shaft. Water jacket? I know to grease the shaft well with some Grim grease. Change the onboard connectors to 5.5 bullets, that is what will be in my lipos. Add a low voltage cut off device. And last but not least, a Grim B/S prop.
    Anyways, i am sure I will have tons more questions once I get my boat and parts. I am all ways reading this forurm.
    • Diesel6401
      Memento Vivere
      • 4203
      Originally posted by pescador View Post
      Don't forget a Low-Voltage-Cutoff. I like the Dimension at Kintec Racing that is set at 3.3v.
      Why are you ordering/using a lipo shield on a esc that already has a LVC?!? Unless you guys know something I don't (which is always possible) sounds like a waste of $$$ to me.
      I time my runs. I usually run about 3-4 minutes and my radio (dx3s) has a timer on it that I can easily start/stop. Before that radio my temp gauge which I bought from harbor freight had a timer on it. I think I paid about $9 for that temp gauge and was a GREAT purchase.
      - Diesel's Youtube
      - Diesel's Fleet
      • pescador
        • 499
        The LVC on the ESC is 11.6v with a warning at 12v. That's a little too low for me it's easy to miss the warning if it's a little bit windy or rough. The Dimension LVC from Kintec is set for 3.3v per cell.
        Namba District 16
        1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
        • Diesel6401
          Memento Vivere
          • 4203
          To each is own I suppose. I have had that motor/esc in 3 different hulls and have yet to hit the lvc.
          - Diesel's Youtube
          - Diesel's Fleet
          • syncronized77
            • Jun 2010
            • 277
            Originally posted by dana View Post
            and i just installed an air damn on it with Wiper blade
            Is this where you place the air dam? How far back from the sponsons? How deep/long off the hull does it have to be? Can it be made from any material?
            Go Brushless or GO HOME
            • dana
              • Mar 2010
              • 3570
              yes. mine is about 2 inches back. i suppose any material will work, i just liked the wiper blade idea. does seem to work well, but then again i wasnt really having any problem to begin with. it does seem a little more planted to the water....
              • osprey21
                • 693
                Not mine, but you get the idea. Should be about 1.5 - 2 inches from the front edge, mounted as shown.
                • syncronized77
                  • Jun 2010
                  • 277
                  It looks like some sort of plastic "L" bracket? connected with double sided tape?
                  OK so couple of inches behind front edge...what about the depth needed? 0.5"?
                  • dana
                    • Mar 2010
                    • 3570
                    you only need the air damn to be 1/2 inch or less. its only there to disrupt air. you dont want it to big or it will just be a plow. alot of guys use the plastic corner gaurd you can buy at most hardware stores. i like the wiper blade because its not hard, it has a little give and disrupts airflow just fine. i tried mine today in some heavy chop that ordinarily would have flipped it, and it did really well. its not rocket science here. like osprey said, 1.5 to 2 inches back is perfect
