feigao 8xl...
  • xxxrems38xxx
    • Mar 2010
    • 172
    feigao 8xl...
    hello guys,
    i receive my new motor 8xl for my ul-1, yesterday i make a test with it and my esc 120A turnigy, i use two lipo 2s 5000mah in serie and the timing motor is on 11.25°! i start the test at full throttle and all is alright for a few seconds and suddenly the power of the motor goes down as if the lipo were discharged while not!
    After i test with a 0.00° for the timing motor and it is the same!
    is the timing motor was wrong or the motor was defective?:cursing
    PS: the stock motor (ammo 2030kv) working very well with my 120A esc on 11.25°
  • syncronized77
    • Jun 2010
    • 287
    What type of prop are you running? Is the 8XL pulling too many amps for your Turnigy 120A ESC? Do you have a beefier ESC to test with the 8XL motor?
    Go Brushless or GO HOME
    • xxxrems38xxx
      • Mar 2010
      • 172
      i use grimracer 40x57/3 blades! i have a 180A esc, do you think the 8xl is good with this? i test with it last week end
      • m4a1usr
        Fast Electric Addict
        • 2036
        Check to see if the battery options is set for auto detect. That typicaly is a reason for the behaviour you are seeing.
        John
        Change is the one Constant
        • lectriglide
          • 540
          I set timing at 7 degrees on all Fiegao motors based on suggestions from several threads on this forum. For me it seems the best combination of performance and temps. I agree with John about what is causing your problem. Set your esc manually for cell count and also check your lvc - I always use 3.4 volts.
          • H&MWill
            • 680
            I use a 8xl on 4S in a H&M Viper. I run the hydra 240LV just to be on the safe side. I think you are really pushin that 120 ESC hard. When you do get it figured out that thing is gonna fly!
            Many issues!!!
            • xxxrems38xxx
              • Mar 2010
              • 172
              yes i think the 120A is to light for this motor! i try with the 180A this week end
              • forescott
                Hopelessly Addicted to RC
                • 3009
                the 120 is perfect. Your LVC is set too high and is kicking in. Re-set it to 2.8 or 3.0 volts/cell or turn it off and time your runs.
                • forescott
                  • 3009
                  3.4 volts is the highest setting and will definetly cause the lvc to kick in early.
                  • xxxrems38xxx
                    • Mar 2010
                    • 172
                    no it 's not that because when i begin the run, the power go down in 5 seconds! i start at full throttle and immediatly the power go down! my lipo are 2 weeks!!
                    • BakedMopar
                      No Mo Slipah
                      • Sep 2009
                      • 1743
                      Its almost garuntees your hitting the LVC. Make sure your batts are up to the task. Use caution when using low or no cutoff values. Just make sure to time your runs so you don't go under the 80% rule.
                      I used a 120/8xl in a 31" shovel nose without a problem. A higher amp esc would be better though.
