UL-1 with seaking 120amp esc
  • v_dub1968
    • 19
    Im courious to see what people think about different esc's in the UL-1. first off i was doing some speed runs with the UL-1 totally stock accept a 40-52 prop. first couple runs was stock with 5000- 20c batterys and every time it was right on 42.7 mph to 42.9 mph i did 3 runs. then i put in a 120 seaking esc after three runs i got 46.2 to 47.3 mph same batterys. I think the seaking has a smoother response to it and it does have more run time on the same batterys :confused2 anyone have a idea why it has more speed and longer runtimes.
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1743
    Unless you changed the timing the seaking's come from the factory with 15* of timing. 5* more than the stock esc.
    • v_dub1968
      • 19
      that is true i forgot about the timing that could make up the differance
        • 9481
        you may have better connections on the different esc to
        I resoldered my connectors and picked up 3mph
        • lincpimp
          • Jul 2007
          • 252
          Connectors will make a huge difference in startup and amp draw. I did a bunch of connector testing with outrunner motors and found that direct soldering beat everything but the nice castle creations large 6mm bullets. Much smoother startups and cooler running wires,esc,motor, etc.
          ILower amp draw and less wasted heat will give you longer runtimes too... I have also noticed that some escs are a bit more effecient than others.
          "These rocky mountains aren't very rocky!" "Yeah, that John Denver is full of S**t!"
          • dreamland s4
            • Dec 2010
            • 347
            seaking 120 esc = awesome!!!!!!!
            If the #2 pencil is the most popular, why is it still #2?
            • dreamland s4
              • Dec 2010
              • 347
              ok.....i had a bad experience with the seaking 120... it fried on me while running 2s 3500mah 40c lipos. BUT im not blaming the esc i have yet to find more 411 on my system components before i point fingers. it ran awesome on my 3500mah 2s 20c
