How to make this setup happen?
  • hyrulejedi86
    • Aug 2009
    • 500
    I was reading alot of people saying that running some lower mAh batteries in parellel at 4s each would help out on the run times and such.
    SO, I was wondering how do you run batteries in parellel in the UL-1? Especially with the double connectors?
    Also, How does this battery look to fit the bill?:
  • detox
    • 2357
    Those batteries will fit and work very well. I hope this picture helps explain how wiring parallel is done.
    • hyrulejedi86
      • Aug 2009
      • 500
      I understand how parellel works and all but I don't know how to hook it up because the Ul-1 has two deans going to the ESC to run in series. I would still want to use other batteries which are still 2s so I don't want to go cutting and editing the UL-1 wiring.
      • BondoBrushless
        • Feb 2010
        • 156
        Excessive wires and plugs absolutely kill effiency.
        • hyrulejedi86
          • Aug 2009
          • 500
          So, it's probably not really easy to do without changing the power wires over to a single connnector then.
          • detox
            • 2357
            This is how I did it using Hyperion 3300 lipos. The Hyperion 3300 lipos will fit any direction.
            I also changed out my motor connectors to larger bullets. The standerd UL-1 motor connectors will eventually fail using more aggressive props and driving
            • BondoBrushless
              • Feb 2010
              • 156
              Rather than a bulky wire harness you could use one of these after you change your ESC to a single plug ?
              http://cgi.ebay.com/ws/eBayISAPI.dll...STRK:MESELX:IT
              • hyrulejedi86
                • Aug 2009
                • 500
                I've seen that adaptor before actually so that means then I'd have to put a single plug on the ESC.
                What if I went ahead and put the single plug on then used a series connector or a parellel connector depending on which batteries I'm running at the moment? Would that be too many connectors on the setup?
                • BondoBrushless
                  • Feb 2010
                  • 156
                  That would be acceptable, use the shortest wires you can and you'll fine.
                  http://cgi.ebay.com/ws/eBayISAPI.dll...m=280526804280
                  • hyrulejedi86
                    • Aug 2009
                    • 500
                    Ok, Thanks alot!
                    • Capt. Crash
                      • Jan 2009
                      • 341
                      I keep hearing this, but I've never had a deans connector heat problem in my stock old UL-1 or the 1:10 Bardahl that uses the stock UL-1 setup. ...and I use 40X57 and X442 props.
                      Crash
