Snapped flex shaft after 5 runs
  • simo71
    • May 2010
    • 74
    Hi all,
    Well I have run my UL-1 now for 5 runs, today approx one minute into the 5th run...it stopped, thinking i had lost the prop. The boat got retreived, to find it spat the shaft from the stub shaft back.
    I have lubed the shaft twice since it was first run using Quicksilver special lube 101 the stuff with teflton.
    The thing is now i have lost a perfectly good Grim prop (40/53) apart from the flex shaft failure.
    I would not expect the shafts to last forever, but as early as 5 runs? Anybody else had early failures?
    Simon
    Australia
    That is very short cable life. A few things to check:
    Fresh or salt water running?
    Sharp bends in the stuffing tube near the strut?
    Remove and dry the cable after each day of running?
    Store cable outside of the stuffing tube?
    Broken end of cable rusty?
    • simo71
      • May 2010
      • 74
      Fresh water.
      No sharp bends anywhere including near the strut.
      Have not removed the cable after each day of running (only been 2 days total or 5 runs).
      Cable has been removed twice, the first time prior to first running the boat & the second time only yesterday for lube.
      No signs of rust at all nor corrosion, very clean brake.
      No binding at all, I do check this prior to each run before installing the packs.
      It really has me stumped as to why it did snap, the boat has been a dream to run up until now.
      • Steven Vaccaro
        Administrator
        • 8932
        Originally posted by simo71 View Post
        Hi all,
        Simon
        Australia
        Just to clarify, it broke right at the shaft? It could have been a poorly aligned flex to prop shaft solder joint.
        Steven Vaccaro
        • egneg
          • 4759
          Did you have adequate clearance between the strut and drive dog? It should be the same as the prop shaft diameter.
          IMPBA 20481S D-12
          • VIKOS
            • Jan 2010
            • 204
            So it should be the same diameter from the dog. Wow didn't know that. This whole time I've been trying to figure out why there was a Lil gap and not flush. Good to know then in that case.
            • forescott
              Hopelessly Addicted to RC
              • 3009
              Absolutely! That is the most common cause of a snapped shaft. That flexshaft needs room to shrink after it spools up.
              • simo71
                • May 2010
                • 74
                That's very possible, though from removing the shaft twice I did not notice anything out of place or alignment.
                As for the drive dog gap? really hard to say now.
                • LarrysDrifter
                  Big Booty Daddy
                  • May 2010
                  • 3416
                  Call Hobbico and talk to someone there about it.Could have been a factory defect.Maybe they will send you a new shaft.And buy an upgraded shaft from here either way.That way if Hobbico sends you a new shaft,you ll have a spare while you run the upgraded shaft.
                  • simo71
                    • May 2010
                    • 74
                    That's all I can put it down to. Still really *!***!***!***!**y I lost a perfectly good prop though.
                    • simo71
                      • May 2010
                      • 74
                      I emailed Aquacraft a couple of days ago, still waiting for a reply.
                      • LarrysDrifter
                        Big Booty Daddy
                        • May 2010
                        • 3416
                        Flex shaft
                        Call Hobbico.217-398-8970.On the automated menu,press 5.Thats the Aquacraft extention.
                        • simo71
                          • May 2010
                          • 74
                          I still have had no luck, I would like to think that Aquacraft where a bit more proud than this. I guess i should forget it about it seeing as though I have a "better" shaft on the way.
                          • longballlumber
                            • 3417
                            The gap inbetween the strut and the drive dog is very important and is listed in the instructions...
                            Was your prop sharpen and balanced correctly? An out-of-balance prop will also stress the entire drive line too.
                            Later,
                            Mike
                            • simo71
                              • May 2010
                              • 74
                              Speaking with one of the people I go boating with said that this was first checked prior to launching the boat for the first time....He done this, hence why was unsure of the gap myself.
                              I purchased the 40/53 with the boat & the main reason why I went for that prop over the 40/57 is due to it being pretty well balanced out of the packet...Well that is the advise i did receive.
                              I have since purchased a new flex shaft along with another 40/53 prop.
