UL-1 ESC Problems
  • v_dub1968
    • May 2010
    • 19
    UL-1 ESC Problems
    I have a ul-1 it has about 6 to 8 runs on it im running 5000 2s 25c batterys. everytime i run it i check the temps and grease the shaft. she runs very cool i thought this was a great boat for me but the other day i was just playing and i had run the boat around for about 1 to 2 min and it just stopped. the esc was fried. it has the big cap on it but it just quit anyone else having this issue ???????
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3186
    How do you know your esc is dead?
    Is your motor spinning no problem? How about the shaft?
    That is strange. There was little issue with the older ESC but not with the one with upgraded CAP.
    Are you able to arm it again at all?
    If you can arm it again after your battery power was disconected than you may need to do some work with your ESC and install new cap or caps.
    See and read this thread:
    http://forums.offshoreelectrics.com/...ead.php?t=9828
    If you can not arm ESC and it's still under warranty sent it to Aquacraft for replacement.
    Last option would be to upgrade ESC but the stock ESC is great for this motor.
    Canada
    • detox
      • 2310
      Sometimes the thin 4mm motor wire connectors build up too much heat causing them to become unsoldered. Replace them using beafier connectors.
      • Grimracer
        • 656
        V dub
        First lets review a few things..
        You are running the boat in clean water. No floating weeds or junk in the water.
        You are running the boat fast most of the time (it can be hard on the controller if you run the boat part throttle all the time
        You are turning the boat right, right! The boat is not designed to turn left. The water pick after all is on the right side of the rudder blade.
        You are not running too large a prop on the boat are you? Truth is for sport running you really don’t need more then around 55mm pitch.
        First things to check are:
        All connectors to and from the controller. Check for any loose solder joints.
        Remove the motor and check the connectors on it as well as well as make sure the bearings are smooth (you are flushing the motor out after a day of running?)
        Now is a good time to check for any other binding in the drive system as well.
        IF’ all the solder joints are good (really check them close) and the controller will not arm.. you have likely failed the part. Send it in the Hobby Services and Im sure they can help.
        KEEP ROCKIN!
        Grim
        • v_dub1968
          • May 2010
          • 19
          Originally posted by Grimracer View Post
          V dub
          KEEP ROCKIN!
          Grim
          yes i have a very clean resevor i like to run it in. i do run it wide open throttle or close most of the time. it has stock prop. after it happin i checked to make sure the cooling system was clear and it was and the drive shaft was free and greased. i did call hobby services and they sent one out right away. i would like to thank them. it wouldnt arm at all so kind figure i might have gotten a bad one.
          • v_dub1968
            • May 2010
            • 19
            i do have a question all my other brushless motors turn over very smooth no drag but this one in the ul1 has always turned kinda hard from the time i got it. . when i first got the boat i took the shaft out and put grim racer grease on it buttery smooth. but i noticed then the motor turned hard. i thought maybe it was the nature of a boat motor but im thinking its my problem now.????
            • v_dub1968
              • May 2010
              • 19
              I just contacted hobby support and they said it should have resistance. hmmmmm sure makes me wonder.????
              • LiPo Power
                • 3186
                That is normal for this motor.
                Let us know how it is with the new ESC.
                Could you post picture of the new one when you get it please? It would be nice to see close up of it.
                Thanks
                Robert
                Canada
                • v_dub1968
                  • May 2010
                  • 19
                  Sure I will post a pic thanks for the help.
                  • longballlumber
                    • 3119
                    I have several that I can take a picture of... What are you looking for?
                    Later
                    Mike
                    • Grimracer
                      • 656
                      The resistance as you put it is the cogging of the magnets
                      IF’ it was a 2 pole motor you would not feel this.. like our AMMO line. Most” multi pole motors have some type of gogging.
                      grim
                      • LiPo Power
                        • 3186
                        Are collecting them?
                        I would like to see close up of the area with new cap installed by Aquacraft.
                        Thanks
                        Later
                        Mike
                        Canada
                        • longballlumber
                          • 3119
                          Thanks
                          They work well for me, I have them in all of my P-Limited (Spec) boats
                          Are you looking for the cap specs, otherwise the caps are attached in the same manner as the old ones.
                          I will try and get a picture tonight.
                          Later
                          Mike
                          • LiPo Power
                            • 3186
                            i would like to know how much biger is the new cap and specs of it.
                            If you have picture with both, new and old side by side that would be great.
                            I know they are good.
                            Thanks
                            Robert
                            Later
                            Mike
                            Canada
                            • longballlumber
                              • 3119
                              Here you go... The new cap is pretty big in physical size. The other picture is the spares I have on hand that are smaller in size and are a step lower on the voltage side.
