turn fin tuning
  • rc_speed
    • Apr 2010
    • 54
    turn fin tuning
    Hello,
    I bought my first boat, a UL-1, and am going to race it at the local club. I have changed the prop to the aquacraft recommended L38X55. I am using Zippy flightmax 30C 5000 lipos. Everything else is stock.
    On the test and tune day, I flipped it one time. Now I see a couple of hairline cracks at the seams. I would include a picture, but I don't think you would be able to see the cracks in it. The cracks don't seem big and they don't appear to be deep. However, when I finished running for the day (4 runs), i pulled the plug out of the back and dumped out about 1/8 cup of water. Is this normal?
    What is the best way to seal the cracks? I bought some marine epoxy. I thought I would mix it up and then spread a LIGHT coat along all the seams of the boat.
    Now for my other question.
    I bought a replacement aluminum turnfin that is thicker than the stock one, but is straight. I did this on the recommendation of a fast guy at the club. He said the stock prop can bend under the forces of use.
    Can somebody explain to me how to tune the turn fin?
    thank you,
    tim
  • longballlumber
    • 3417
    On page 7 and 8 of the manual there is some info on tunning the strut, rudder, and turn fin. I would suggest starting there to establish the basics. Once you've done that, test test test. While testing keep notes on what you changed and how it affected the performance and handling of the boat. Only change one thing at a time. If you make more than one you won't know which change had the most affect on the performace.
    Most important, HAVE Fun!!!
    Later
    Mike
    • Capt. Crash
      • Jan 2009
      • 341
      Originally posted by rc_speed View Post
      Hello,
      No...you should have NO water in the hull at the end of the day. If it's not leaking in those cracks, it could be leaking around the stuffing tube where it enters the hull....mine did.
      I have great luck running thin CA glue into those hairline cracks.
      I tried the straight fin and didn't like it, went back to the stock one.
      This should not be a problem unless you thin it down too much.
      That is down by adjusting it up or down per the instructions in the manual. I just leave mine all the way down.
      thank you,
      tim
      Hope this helps some
      Crash
      • BakedMopar
        No Mo Slipah
        • Sep 2009
        • 1743
        I lost my original plug and the replacement I got was much harder. I now have had water in the hull too. Took that out and covered with tape. Now my hull is again watertight.
        • rc_speed
          • Apr 2010
          • 54
          ok, thanks. I spread some super glue in the tiny cracks that I got. I smeared it along some of the seams. I also spread a bead of epoxy around the joint where the prop tube enters the bottom of the hull. If it still gets water in it, I will try taping over the plug hole
          I have my first race on sunday, so I will find out how it does then.
          • Capt. Crash
            • Jan 2009
            • 341
            It's also possible that it's leaking around the bolt holes on the transom or turn fin sponson. I always pull my bolts and dab some clear RTV sealer around the holes and under the brackets then retighten the bolts.
            Crash
            • Jeepers
              • May 2007
              • 2050
              I think you meant the turn fin.
              and yes the stock plastic prop can and does flex.
              • rc_speed
                • Apr 2010
                • 54
                oops, I meant turn fin. thanks for the correction.
                I saw somewhere that the boat can face 3-4 g's of force during a turn in a race. This can equate to a force on the fin of 3-4 times the weight of the boat on that fin.
                I tried to order better fins from kintecracing, but they are out of stock and the replacement production is going slowly. In fact, they refunded my money and told me to re-order them when the web site says they are in stock.
                Is there somebody else that makes a replacement turn fin for a UL-1 that is better than the stock one? I know I can make my own, but I would rather buy one.
                thanks,
                tim
                • Diesel6401
                  Memento Vivere
                  • 4391
                  thanks,
                  tim
                  Scroll to the bottom, 3 to choice from. http://www.offshoreelectrics.com/products.php?cat=67 stock one is their as well other two have similar dimension except stock is .01" thicker & .15" shorter.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • Jeepers
                    • May 2007
                    • 2050
                    thanks,
                    tim
                    3-4 g's maybe more, (I don't know) I read someone data logged 7g in a UL1 powered rigger.
                    I don't know of anyone else that makes a replacement fin, make your own, I use stainless but it is a pain in the A$$ to cut and work.
                    • Diesel6401
                      Memento Vivere
                      • 4391
                      7gs, really? that's nuts. I wouldn't have ever thought a rc boat could pull that. 3-4 is a good bit, but 7 WOW you figure a military jet pulls around 10 in high g turns. Impressive
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • Jeepers
                        • May 2007
                        • 2050
                        yep and they all bend under hard cornering. in my opinion they flex to much to give precise cornering.
                        Tim you could add some bracing like in this pic, and attach it to the side of the hull.
                        • Jeepers
                          • May 2007
                          • 2050
                          Diesel here is the post I saw on the rigger, the data was logged by Eagle tree system
                          • longballlumber
                            • 3417
                            thanks,
                            tim
                            Tim,
                            I have one of the kintec straight fins I can sell. It's brand new, never used. Let me know if your interested.
                            Later
                            Mike
                            • Diesel6401
                              Memento Vivere
                              • 4391
                              Originally posted by longballlumber View Post
                              Tim,
                              Later
                              Mike
                              If he doesnt take it I will. I want to try it on my 7xl setup.
                              - Diesel's Youtube
                              - Diesel's Fleet
