Resurrecting a Superior
  • Diesel6401
    Memento Vivere
    • 4391
    Well after the wicked crash I looked it over and decided attempt to re-build. So far I sanded it down to the fiberglass, laid new fiberglass and then and started to re-sand. After I laid the fiberglass I did a leak test in the bath tub and all went well. I started to resand and get a smooth finish today and found a few area's that need to be addressed before I continue. After I am done sanding (hopefully tonight) & adding some additional fiberglass to some week spots I will put all the hardware back together and run it like that. If all goes well and it runs good I will then re-paint. I ordered another esc for my set up. I keep debating on whether I want to attempt the 7xl set up again or go back to stock power. I don't want to give up on dialing this boat in with the 7xl set-up, but their is a lot of work to do with it.
    - Diesel's Youtube
    - Diesel's Fleet
    • 9481
    right on man, right with ya on this!
    • Rumdog
      • 6667
      Good job bro! Are you going to fill the sponsons with expandable foam?
      • Diesel6401
        Memento Vivere
        • 4391
        I'm not sure. If I do that would it limit my ability to splay the batteries through the sponsons?
        Ammo 2600 is too high kv for 4s. My Ul-1 coulsn't handle the power of the 8xl. Lots of chine walking! The ammo 2300 may be an option. IMO the stock motor is plenty for this boat though. Maybe upgrade to a 120 amp esc and try propping up a tad.
        I need more weight. The boat still would not keep the front down even with 2 4s lipo's in normal battery config ran in parallel. The 7xl may just be too much motor. I may step down to a ammo 2300 with a sv esc? Any thoughts to how that would work?
        Rum you called the 2300 a long time ago as an option. You may right with that.
        - Diesel's Youtube
        - Diesel's Fleet
        • Colby
          • Dec 2009
          • 54
          Jesus Christ ... what wicked crash? My hat is off to you wanting and trying to fix the body ... I'd probably just buy a new hull. Let us know how it comes out.
          • Diesel6401
            Memento Vivere
            • 4391
            Hit a possible turtle at 51mph on the gps. It was actually a pretty clean break. Thought about scrapping i, but had a crap load of fiberglass and resin laying in the shop so said what the hell I'll give it a try. Only took about 5hrs. I just finished tending to the gaps I found, so I should be done tomorrow. I'm just waiting for it to cure right now.
            - Diesel's Youtube
            - Diesel's Fleet
            • Colby
              • Dec 2009
              • 54
              Just read down to your other post regarding the crash ... holy sh**. I'm looking at upgrading my UL-1 as well but now may give it a second thought ... high 40's may be fast enough.
              • Diesel6401
                Memento Vivere
                • 4391
                It was blast on the 7xl (video is in my signature if you haven't seen it), sadly I just didn't have enough time to dial it in. Crash before I could try somethings, i.e straight turn fin to loose some lift or airdam for a few. I think like rum said a 2300 ammo may just be that happy spot.
                - Diesel's Youtube
                - Diesel's Fleet
                • Diesel6401
                  Memento Vivere
                  • 4391
                  I just finished repairing the the nose cone. Luckly for more when it broke off the the cone floated and the the broken piece was still taped to the hull. I cut some fiberglass up and mixed it with the resin. I use tape to hold the pieces together while it cured, seems ok now and strong.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • BHChieftain
                    Fast Electric Addict
                    • 2051
                    I need more weight. .....
                    I would think by adding foam in the sponsons would help with weight, and you could still dig out holes for the lipos-- you might even get a more secure fit for the batterys that way.
                    I love that boat of yours, glad you decided to repair it!
                    -Chief
                    • Jeepers
                      • May 2007
                      • 2050
                      Colby dont worry about breaking the hull, fiberglass is easy to repair! Plus there are a few boat modelers down here in Pueblo that could easily fix it! Diesels hull just split at the seam, pretty common actually, oh and don't hit a bouy with these hulls either, the damage looks about the same.
                      • Diesel6401
                        Memento Vivere
                        • 4391
                        -Chief
                        I'm kinda of scared of the expanding foam. I have a heavy hand I don't want to spray to much and spilt the hull again. I'm still open to the idea though seeing people way more experienced than me are suggesting to do it. I have yet to re-work the turn-fin area so I would want to do that before I add foam though.
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • Rumdog
                          • 6667
                          use small shots, let it cure for an hour and add more as needed. Since your tub is cut out for the lipos, the foam will always have somewhere to escape so it won't blow up the hull.
                          • Diesel6401
                            Memento Vivere
                            • 4391
                            Is their a specific brand or type I should purchase? I imagine Home Depot or Lowes would carry it.
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • ncornacchi
                              • Jul 2009
                              • 256
                              Keep the project going Diesel....You and I have been on the parrallel build path with the 7XL in the UL-1....I've been watching your build and test very carefully....It's not too much motor...Mine was hopping and dancing so badly that I thought I had it over-powered too, but moving my strut down and messing with the angle has made the UL1 pinned to the water and very stable.....slowed it down to 47mph, but at least I know that it will stick, now I only have to tweek it back up and find the sweet spot...I'm running the CC240 in one and Etti 150 w/caps bank in other, and I am pleasantly surprised with the Etti (cost and performance)....BTW, both of mine were total wrecks, fixing them is half the fun....Norm
