Run Time
  • Crazzymugen
    • Feb 2010
    • 7
    Run Time
    Gday guy's Just want to no how long should i get out of 2 5000 zippy 30c Battery's At the moment i am getting 7 minutes.
    Prop being used is a Grim L40x57
    Cheer's Dave..
    • 7990
    Seven minutes until what, the LVC? You are pulling under 40 amps average - pretty low. I'd say you are getting plenty of run time; a lot depends on how you run: how much WOT, how much acceleration, etc.
    • Capt. Crash
      • Jan 2009
      • 301
      7 min. sounds about right...I run 3 ea. 2.5 min. runs at full tilt on 5250 30c and am done with those packs for the day.
      Crash
      • Crazzymugen
        • Feb 2010
        • 7
        Thank's for the reply Guy's
        Look's like im going to need 6 more lipo's
        7 min's not enough run time .
        Just to let you guy'e no that here in Australia you can not get the ul-1
        I Went to the Australian toy fair yesterday were us retailers go all i can get is the supervee 27 some thing wrong there.
        Check out these Boats . www.fs-racingart.com
          • 9479
          7 min of run time is very good for a UL-1
          how many Mah are you putting back after 7min?
          I usualy only run 5 1/2min max with my UL-1 on my Turnigy 5000mah 30C packs
          • Crazzymugen
            • Feb 2010
            • 7
            The Pack's take 5150 mah after charging .Zippy 5000 30c
            These pack's have been great.
            • egneg
              • 4664
              That time is great ... I only get 2 - 3 minutes until I crash & burn.
              IMPBA 20481S D-12
              • Crazzymugen
                • Feb 2010
                • 7
                Look's like im haveing good luck then.
                Did u guy's check out the web site link www.fs-racingart.com
                  • 9479
                  You could possibly hurt the packs running them down 100%
                  • Crazzymugen
                    • Feb 2010
                    • 7
                    I run the ul-1 until the 12 volt stutter warning comes on.
                    As for the pack's She'll be right mate.
                    The charger i use is a Swallow Advance.
                      • 9479
                      well the UL-1 esc goes way low for a cutoff
                      and running packs beyond 100% will shorten their life span
                      but if that's the way you want to run, run it..
