RIO EP or UL-1?
    • 9481
    #46
    Originally posted by erevo09 View Post
    thanks everyone for your inputs on my questions.
    i guess now i am choosing between SV27 and UL-1 now coz i just dont think RIO EP is fast enough for me unfortunately...
    i have one other question: can anyone recommend a good rescue boat since i dont have a good boat retrieval system...
    My vote goes to the SV27.. you will have alot of fun with this boat and it will get some good speeds with a different prop and good lipo packs
    It's still one of my favorite boats to just go bash with..
    • erevo09
      • Jan 2010
      • 22
      #47
      with sv27, what do you guys do when using lipos with it?
      • Diesel6401
        Memento Vivere
        • 4391
        #48
        Add a lipo shield., move the batteries forward. http://kintecracing.com/Supervee_27_upgrades.html
        - Diesel's Youtube
        - Diesel's Fleet
        • erevo09
          • Jan 2010
          • 22
          #49
          thanks man!
          do you use the exactly one with your SV27? did ur boat ever get stalled because it ran out of juice?
          i found this (for 2s lipos) on the internet, they should work right? but does that mean i gotta attach 2 of them since SV27 uses 2 batteries?
          also, how do you connect the white connector to the read/black wires?
          man, i am getting my boat today and i am leaning towards SV27 than UL-1...
          • Diesel6401
            Memento Vivere
            • 4391
            #50
            I would lean towards the one i sent you the link for on kintec that already has the deans installed. That way you can take it out and put it in whenever you want. No you dont need two. If you get the one with the deans it has two connections. You plug the esc into the lipo shield and your batts into the esc. Give me a sec I'll take a pic. If you get the one you have listed you have to solder into the esc, not a big deal.
            - Diesel's Youtube
            - Diesel's Fleet
            • erevo09
              • Jan 2010
              • 22
              #51
              do you use the same one yourself?
              by the look of the pic, i have to say those battery wires look very THIN, is that gonna be a problem?...
              • Diesel6401
                Memento Vivere
                • 4391
                #52
                Nope, I haven't had a single problem yet. I honestly never run my batts until the warning kicks in. I time my runs.
                - Diesel's Youtube
                - Diesel's Fleet
                • Diesel6401
                  Memento Vivere
                  • 4391
                  #53
                  Pic 1 is the esc plugging into the lipo shield
                  Pic 2 is the batt connections from the esc plugging into the lipo shield connections then you just connect your batt to the lipo shield
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • erevo09
                    • Jan 2010
                    • 22
                    #54
                    how much time do you think i can get out of TWO 2s 28C 6000mah lipos with sv27 with conservative throttle (stock setup)?
                    • Diesel6401
                      Memento Vivere
                      • 4391
                      #55
                      If your running "conservative" watch your temps. Running half throttle really heats things up and the esc doesn't really like it that much. In terms of run time: http://www.offshoreelectrics.com/conversion.htm
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • erevo09
                        • Jan 2010
                        • 22
                        #56
                        thanks, its a useful tool.
                        28C 6000mah only gives me 12 mins of run time.... was expecting more than that...
                        its just when i play rc, i do stop quite often, i dont normally run it for like 20 mins full throttle until the battery dies.
                        • Diesel6401
                          Memento Vivere
                          • 4391
                          #57
                          its longer than you think. After 5-7 minutes Im ready to bring it in...
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • erevo09
                            • Jan 2010
                            • 22
                            #58
                            i dont quite understand for my rc trucks, a set of batteries can last me almost 1 hr if i play conservatively.
                            boats are different?
                            • Diesel6401
                              Memento Vivere
                              • 4391
                              #59
                              Boats are power hungry. The constant friction/drag caused by water takes it toll on batteries and esc. You have to have a good "C" rating on your batts. I use 25C & 30C and I'm about to buy some 40C's. Because of this run time suffers.
                              - Diesel's Youtube
                              - Diesel's Fleet
                                • 9481
                                #60
                                Alot depends on what prop you use..
                                bigger props pull more amps, possibly 70-75amps with a CF48 like I use
