Brushless wildcat
  • minikitty
    • May 2010
    • 27
    Brushless wildcat
    Bought a mini wildcat about 2 weeks ago, and now i wanna go brushless. What size brushless will i need to go 50mph +? I know its dual motors and it will need two brushless set ups. Also how do you think it will handle at 50mph
  • forescott
    Hopelessly Addicted to RC
    • 2686
    I would like to see a wildcat go 50mph. I think it would probably take flight at about 40!
    • minikitty
      • May 2010
      • 27
      well i wanna see it take flight. but being able to go 50mph. What kind of motors do i need
      • forescott
        • 2686
        Something like a pair of feigao 380s in the 4000kv range. Look em up under brushless motors here on the ose site. Good luck with your build!
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3480
          I'm already on it. Have a thread going on it and a brushless setup on the way!
          • minikitty
            • May 2010
            • 27
            Just a set of these motors? What esc would i use to power these?
            http://www.offshoreelectrics.com/pro...prod=fei-380-S
            • minikitty
              • May 2010
              • 27
              how about two of these?
              http://www3.towerhobbies.com/cgi-bin...?&I=LXUFF0&P=7
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3480
                Check out this thread; http://forums.offshoreelectrics.com/...ad.php?t=14585
                And this one: http://forums.offshoreelectrics.com/...ad.php?t=14882
                The motors are tiny, but there are two bolt patterns in the mount, less than 380 sized holes.
                I'm starting with a 35-40 amp setup and if it's not enough, going up to 60amp. But battery life becomes an issue at that point.
                Jeff Wohlt can make specialty couplers for whichever motor setup you choose. www.rcraceboat.com, just email him and ask.
                The props are 1/8th.
                  • 5554
                  Originally posted by minikitty View Post
                  Those motors would last about 10 seconds at 9000kv.................. As forescott mentioned 3500-4000kv on 2s would work alright. Something along these lines
                  http://www.hobbyking.com/hobbyking/s...hless_Inrunner
                  Fightercat sniffed these out..............whole setup for $40......need two of course.
                  http://www.hobbyhot.com/swanghobby-m...1-pr-2307.html
                  • minikitty
                    • May 2010
                    • 27
                    Alright. what kind of ESC would I use to power the engines
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3480
                      HK has a few 35-40 amp esc's. They need to be conformal coated or silicon sealed though. http://www.hobbycity.com/hobbyking/s...ies_35-40A_ESC
                      You can also add a water cooled heat sink instead of the one that comes with it. There's some floating around, ETTI makes them and OSE has them.
                      Whatever motor you choose, size the ESC above it's max amp rating and you should be OK.
                      • Alexgar
                        • Aug 2009
                        • 3522
                        I did a single brushless mini vee 28-47 2700kv 40 amp esc 3s and 4s on stock hardware. Durability becomes an issue quickly with this much power. Also the weight to power ratio get skewed quickly as it is hard to have something so fast and light keep in the water considering at 30 mph a ripple is a titlewave.About 300$ in to it im now looking for a 16-18" fg hull to tranplant my goodies.Probably a bby warzone jr since i have all the hardware from a brushed one i had many years ago
                        • sailr
                          • Nov 2007
                          • 6924
                          Everybody always wants to go faster. Remember, there is a point at which the boat becomes uncontrollable! What's the point!!!?
                          Mini Cat Racing USA
                          www.minicatracingusa.com
                          • minikitty
                            • May 2010
                            • 27
                            This esc you showed me has bad reviews of burning up. also how hard will it be to wire in two motors? Also what kind speed will i see from this set up you have shown me?
                            • minikitty
                              • May 2010
                              • 27
                              also i'm probably not going to be running a lipo. just a custom built nimh battery pack
