Brushless Wild Cat?
  • GTX
    • 9
    #46
    Is there such thing as a single ESC w/ BEC that will run two motors ?
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      #47
      So far, no. But I've gotten two ESC's to share the same cooling block and shrink wrapped them together successfully. When the other ESC comes in, I'll post some photos of it going together. It takes up much less room shrinked up as one unit.
      • GTX
        • 9
        #48
        Hmm that is too bad....but how about this.
        two brushed Frenzy 370's one brushed ESC with the two motors running off it in parallel ?
        I think the airplane guys do this ?
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3480
          #49
          yeah, as far as I know, you can run two motors off of a brushed ESC. The stock wildcat uses an ESC/Rx all in one with two brushed motors. The generic brushless ESC's are only about $10... http://www.himodel.com/electric/HiMo...pe_GX-30A.html
          OSE has the water blocks to cool them. Mount them back to back and you're good to go.
          • turboed13b
            • May 2010
            • 9
            #50
            Im runnin the frenzys with the mlst esc i need to run smaller props as the battery gets hot.
            • Mash13
              • 40
              #51
              I love these mini boats! I have a mini C, its been a pain in the butt with water ingress and the ABS is cracked up. Pity these little boats that look so scale cant be easily modded. your build looks great!
