New MC changes, rebuild. New motor ?
  • MucFlyer
    • Sep 2016
    • 8
    Hi All
    I do have two MC, one was with destroyed hull, one brand new. Finally I have two ESC (Original one and Dynamite Marine 120A), OSE flex with 42x55 GrimRacer. Now I thought, to sell both motors, one original ESC, keep Dynamite and get new motor. Idea is not to have in fact more speed, but to keep it cooler, and on safe side with 2x2S. Any thoughts ? Dynamite ESC should be just fine.
    • 7990
    I assume you mean 4S1P and not 2S2P. I think your plan is a good one, and depending on the motor choice gives more flexibility in power and speed.
    • MucFlyer
      • Sep 2016
      • 8
      Yes, indeed 4S1P. Any motor recommendations ? As I said, I preffer to stay on safe side instead of crazy speed.
        • 7990
        One motor which is an upgrade for higher efficiency (and a bit more speed if desired by propping up) is the TP3640/1935 motor. Larger and of higher quality than the stock motor, it should work well.
        • MucFlyer
          • Sep 2016
          • 8
          Not easy to find in EU... should be Wind 4Y, Flat spot on the shaft?
          • MucFlyer
            • Sep 2016
            • 8
            I think I did mistake ordering TP3640 4Y 2540KV ... can anyone confirm, or maybe will it be ok to use ?
            • iop65
              • Mar 2013
              • 367
              no problem for 4s use in this hull
              • MucFlyer
                • Sep 2016
                • 8
                My question was more related to motor use, if TP3640 4Y 2540KV won't be overkill for this hull.
                • Mxkid261
                  • Jun 2015
                  • 734
                  You should have no problem running that motor on 4s, like with any new setup changes, just make sure you check you temps closely your first few runs. Let us know how it runs, I'm ready to pull my MC from the shelf and give it new power.
                  • MucFlyer
                    • Sep 2016
                    • 8
                    I can report back right now, this motor doesn't fit. It is too long...wrong decision. So I'm looking again for new motor...not spending another 100 Euros, to get wrong one.
                      Post some pics of why it's too long. My buddy has a castle 1515 in his which is bigger diameter and about the same length.
                      • MucFlyer
                        • Sep 2016
                        • 8
                          I see. You may have to do some modification to get that to work like flipping the motor mount around and shortening the stuffing tube, flex and whatever else you can shorten.
                          • Mxkid261
                            • Jun 2015
                            • 734
                            You should be able to make that fit by flipping your motor mount. I run a castle 1420 (spartan motor) in mine and it fits no problem. I believe its 82mm long.
                            • JJ1TRXSAton
                              • Oct 2016
                              • 88
                              Any updates? I just put my MC together with a 3674 / 1900KV and the canopy wouldn't close. Flipped my motor mount around, drilled new holes for right position and shortened the flex shaft and it fit just fine...
                              James J.
