Lucas Oil sponson blueprinting
  • properchopper
    rcgoatbuild@snotmail.com
    • 6958
    Oh Boy Jim, PLC is gong to be fun now !!!
    I like to run the strut up high to keep the motor a tad unloaded & up a bit to get the front of the sponsons out of the water under wot.
    • iop65
      • Mar 2013
      • 367
      mine : back of strut is about 1.5 mm above sponsons with a very small neg angle
      • BHChieftain
        Fast Electric Addict
        • 1964
        +1 on what Propperchopper said. Also, if you blueprint you can run the strut angle flat. See my note above for a how-to on blueprinting.
        Chief
        • boatracr157
          • Aug 2012
          • 6
          Thanks to the info. I watched your tutorial and blueprinted the bottom the way you suggested. It came out very nice. Flat & sharp edges.
          Jim
          • moomba45
            • Jul 2015
            • 1
            I just received my Lucas boat yesterday and was wondering about strut height. The Lucas hull has stepped sponsons, and when set on a flat surface the back of boat is up off of surface due to the stepping. Should I set as boat sits? Or do I hold back of hull down on surface and then set height?
            • jonesjj
              • Aug 2015
              • 45
              I just got the Lucas Oil from Jim looking forward to what guys end results were with the blueprint and if anyone has input on what moomba45 just posted.
              • fox88gt
                • Jul 2013
                • 103
                I don't have back-to-back GPS data for a before/after comparison yet but I can verify that the boat needs much less positive angle on the strut to carry the bow, which should equate to higher speed. After blueprinting, I ran the boat with the same strut angle as before, and the boat porpoused because it no longer needed that much positive angle. The boat handles better and certainly appears faster.
                Aquacraft Revolt 30, Aquacraft Lucas Oil Cat
                Dumas 44' Coast Guard MLB (undergoing restoration)
                Dumas 55" Wellcraft Scarab 38KV (NIB kit)
