Prop questions
  • TrimmedOut15
    • 17
    Prop questions
    I have a completely stock MC, I know I have to adjust my center of gravity and strut but wanted to know what prop you guys think is best for my stock setup. I have 640,440 2 blade and 3 blade 440, also have a 445. I don't have a 442. Also all of my props are balanced and sharpened but they all have the tounges on them. Does de-tounging make that much of a difference?
    Thanks for your help
    • 7990
    The x445 will give good speed and decent run times, but check for high temps in warmer months. Removing the tongue will make a small difference, you probably won't notice on your setup without a GPS.
    • TrimmedOut15
      • 17
      That is how I am testing, with a GPS, I'm sure it is slowing me down bc of the weight of it but it gives me the most accurate readings of my setup. I have a balancer coming so you recommend removing the tounges? What would you say the temps should be with the 445? Thanks for your help
        • 7990
        Temps also depend on run time, air and water temperatures. Be certain to check temps as soon as possible since components cool off rapidly. On a sport setup once you get above 140F you are too hot.
        • TrimmedOut15
          • 17
          Ok great, thanks again. Have you ever tried a 3 blade? I have a few of them too, just curious how they will work
