Just ordered a motley crew. Have some questions
  • shartinspartin
    • Aug 2013
    • 257
    I just picked up a motley crew on tower in the scratch and dent area. Its says it has a damaged prop and missing small parts.
    What is a good prop to throw on the stock setup.
    Also I have a brand new castle vxl6s spartan esc, and an almost new castle spartan motor. (Im about to upgrade the spartan)
    Would that setup be an upgrade over stock And would it run in this boat reliably?
    Is there anything out of the box that needs to be done before the maiden?(besides figuring out what the missing parts are lol)
    If theres anything else you can add id appreciate it!
  • shartinspartin
    • Aug 2013
    • 257
    pretty dead here huh???
    • JimClark
      • 5913
      pretty impatient? Slightly over two hours ago on a Saturday afternoon give it time
      Billy Graham
      • shartinspartin
        • Aug 2013
        • 257
        The most impatient. LOL
        Im just used to being on forums for every type of rc that have alot more traffic.
        But anyways... Do you have any input on the op?
        • Denaki
          • Sep 2013
          • 1
          Search or just look through the other threads, it's all out there if you look. I just got one myself and looked, just upgrade the shaft and prop and your good to go!
          • turbomania
            • Aug 2013
            • 28
            A Grim 42-55 is a good prop, also like the Octura X442 on this.
            This boat is very happy running in the 40's, I do believe the Spartan Electronics will fit. I would run it stock first to get a feel for it, set up is most important !!! Once you upgrade, Blow overs at 50+ mph will kill your Motley, and most other RTR's... Then Aero tweeks need to be done to keep it on the water.
            Love mine... 66.9 MPH...
            PS make sure to line up the drive cable and the motor. They are usually way off. The motor mount is very thin and will twist out of alignment.
            Turbo Joe
            Motley Crew, Neu-Castle 1515 1Y 2200, 22 Volts, 180A ESC, Custom Motor Mount, .187 drive cable. Aero mod.
            Best 74.1 mph, Average 71 mph.
