Newbie help
  • lidebt2
    • Jul 2013
    • 6
    Newbie help
    The tube that is by my finger has backed itself out of the prop cable shaft. How do you prevent it from happening?
    Thanks.
  • bdp1174
    • 146
    If the Teflon liner(which you are pointing towards) is moving or spinning you can cut a small piece of water line tubing and put it over the brass tube and the Teflon liner and that will hold it in place and keep it from spinning. It also helps keep water from coming up the tube. Mine used to slide towards the motor under throttle and after putting the tubing on it fixed the problem.
    • lidebt2
      • Jul 2013
      • 6
      Thanks will try it.
      • BHChieftain
        Fast Electric Addict
        • 2051
        But note that having that tube slide around really isn't a problem. It acts as a spacer to fill the gap between the flex and the stuffing tube.
        Chief
        • petej
          • Jun 2010
          • 163
          Teflon liners do wear out and need to be replaced. I've run my MC and do run both my twin-screw cat and my Impulse without the teflon liner. Either way, you must keep the flex-shaft, stuffing box well greased.
          Pete
          Motley Crew, Impulse 31, Zonda Cat, Genesis, Aqua Rider tug, E-Revo Brushless, Slash4x4
