Seaking 180 problem
  • 704Authentic
    • Nov 2012
    • 178
    Seaking 180 problem
    Programmed the ESC. Made a few runs - slower than expected. Temps at 90.
    Cannot get back in to check settings.
    Followed wiring sequence (ESC w/out built-in BEC.) and batteries are charged.
    Looking at flat lines on program card and motor moves when it beeps, when connecting power pack to ESC.
    Lost.?
    AquaCraft UL-1 59mph.
    Motley Crew 61mph.
    JAE 21FE ~~~ 70 MPH Club ~~~
    • 4297
    Hey.
    Is the esc rx/program plug in the right way in the program box ?
    And is it in the slot at the far right of the program box ?
    Also you can just us a 2s pack to work with when trying to program the esc.
    Have any pictures you could post or a video to see what you are talking about ?
    Are you using the stock tactic tx & rx ?
    If so did you calibrate the tx to the esc first and also set the tx throttle trim switch to R , Before you tried programing the esc ?
    • MAMBA2200
      I need a scooby snack
      • 1196
      The slow run was probably caused by the lvc set to high turn it off when u get back in to program it and time your run start at 3 min and stop
      Sent from my FE Phone
      • 704Authentic
        • Nov 2012
        • 178
        rx/progam plug in far right.
        Using different battery packs.
        Stock tactic tx & rx.
        Calibrated the tx to the esc first and also set the tx throttle trim switch to R , before trying programing the esc. Yes.
        But, I may not have used the "reset" button each time after "value".
        Still unable to get in, motor beeps and looking at horizontal lines on program card.
        Motley Crew 61mph.
        • 704Authentic
          • Nov 2012
          • 178
          You are probably correct - Looked like half power. Will turn off lvc, when/if able to get back in.
          Motley Crew 61mph.
            • 4297
            Can you post some pictures of everything in the setup & tx/rx /card/ please ?
            And did you try a rebind to the tx to rx ?
            • 704Authentic
              • Nov 2012
              • 178
              Sorry, unable to download pictures at this time.
              Rebinded tx to rx. Motor runs, red light on ESC comes on under full power.
              Still looking at horizontal lines on program card.
              My Set-up:
              Castle 1415 2400kv
              Seaking 180
              (2) 4500mah 2s 50-100c
              All on 6.5 bullets
              42x55 prop (starting point)
              foamed
              Motley Crew 61mph.
                • 4297
                Is your esc rx plug,
                Plugged in to the program card slot on the right hand side of the card ?
                And the plug wires black, red, white, White wire of the plug on the right side of program card ?
                • 704Authentic
                  • Nov 2012
                  • 178
                  All the way to the righthand side - yes, in that extra funny marking.
                  White wire of the plug on the right side of program card - yes. (Red wire cut.) ?
                  Motley Crew 61mph.
                    • 4297
                    No red wire cut,
                    Are you using no bec ?
                    With a separate rx batter pack in the setup ?
                    • 704Authentic
                      • Nov 2012
                      • 178
                      Yes, using a separate rx battery pack and following wiring sequence for ESC w/out built-in BEC.
                      I read on OSE '...cut the red wire.'
                      Not correct?
                      Motley Crew 61mph.
                        • 4297
                        When doing separate rx just pull the red wire connector out of the plug,
                        Than you can always put it back when you need it.
                        Try to reconnect the red wire and just use the internal bec of the esc and try the program box again.
                        • jsturess
                          • Jan 2013
                          • 38
                          Which version of seaking?
                          • 704Authentic
                            • Nov 2012
                            • 178
                            180 with 4 extra cap banks, I think it's a V2.
                            Motley Crew 61mph.
                            • 704Authentic
                              • Nov 2012
                              • 178
                              It's a Seaking 180, a recent purchase from OSE.
                              Motley Crew 61mph.
