New MC not working HELP
  • Big power
    • 20
    Just unboxed new MC. Brand new tested and charged lipos (ran in my slash today). Turn on controller, I plug in both charged tested batts (Grim 5000mah 40c 2s) no beep. I do the T trim trick nothing. I try the N R switch on trim nothing. I try pressing the little button on the receiver to bind the controller, no little LED light. I think the ESC is blown from the factory.
  • sanyijr
    • 376
    Volt test the power lead as close to the ESC as possible. If you have power there, I would assume esc is bad.... You have a series connector i assume? Could be bad contact there. That is why I say Volt test at esc on the power in side.
    • Grimracer
      • 656
      2S is not enought voltage to operate the system.
      Grim
      • sanyijr
        • 376
        Grimm,
        "LIPOS" I assume here we are working with 2 2S packs.... But you might be right. BigPower?
        • Big power
          • 20
          http://www.amazon.com/dp/B005EFY7HS/...T1_ST1_3p_dp_2
          These are the lipos I used?
          • sanyijr
            • 376
            BP,
            So you have two and you hook both up the the stock esc? That make it a 4S setup. If you only have one plugged in, it's 2S and as Grimm stated, low voltage and no good.
            Do you have a voltometer? (Volt meter?)
            I mean if all is stock, 2 packs 2S each are plugged in, and they are charged..... Looks like a bad esc as assumed...
            Wouldn't say "blown". That implied overloading it and the this popping due to use. Most likely a short or faulty solder connection....
            • Big power
              • 20
              Correct 4s. Aquacraft is sending Esc free of charge.
