Take a look please/setup help
  • xlandguy
    • May 2012
    • 293
    Tried to take some pictures showing how my rudder and strut are set. Also, the pointed prop nut. Should there be another small nut in front, a double nut? How tight should I try to get this prop nut? Tight as I can or? I assume that because of the rotation of the shaft/prop the nut is not easy to come off while running? I am wondering about the angle of the rudder and the height/angle of the strut. Thank you.
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3416
    Throw the bullet nut in the trash, unless you want to make prop donations to the bottom of the lake. Use a zuber nut instead.
    • xlandguy
      • May 2012
      • 293
      I'll have to order some. Until then how about some blue Locktite on the bullet nut? That should hold it?
      • iamandrew
        • 576
        Even with semi permanent Loctite you dont wanna use those prop nuts!
        i had one come off, and was lucky my rudder stopped the shaft from coming out
        • xlandguy
          • May 2012
          • 293
          Ok, thanks. I sure hate worrying about one of my new metal props coming off. Especially after I spent so much time trying to balance and sharpen it.
