Stock ESC and motor?
  • alvinm
    • Feb 2012
    • 77
    I posted this question in another unrelated thread, so I figured I'd get a quicker response here..
    Will the stock setup handle two 3s lipo's, or a 3s and a 2s with the same mah?
  • DjFlipNautikz
    • Jan 2012
    • 70
    don't take my word for it but if i am not mistaken i read that it can handle upto 5s if you install a UBEC or if you remove the red wire from the connector of the esc to the reciever and install a seprate RX battery pack.
    my friend however which is on here told me he tried 5s with out any modifications and that everything ran cool.
    but i am a n00b so hopefully some more experienced people will chime in.
    Good Luck
    • dana
      • Mar 2010
      • 3660
      6s no. The motor will handle 5s but I'm not sure about the esc. 2s+3s same mah ok
      • longballlumber
        • 3417
        I would suggest to stick with 4S otherwise you will run the risk of failure or shorten the life of the motor.
        Later,
        Mike
        • alvinm
          • Feb 2012
          • 77
          Its plenty fast with 4s, its just that I have an extra 3s pack I would like to use..
          • Make-a-Wake
            FE Rules!
            • 6057
            Try the stock setup with an x640.................... If you run a 2s and a 3s they need to be the same mah and "C" rating!
            • DjFlipNautikz
              • Jan 2012
              • 70
              I have a question. I run my MC parallel instead of series so i have two Turnigy 4s batteries 5000mah. BUT they are slightly different C rating one is 25c- 35c and the other is 40c - 50c
              is that a problem? even though i think it is a little late for that as i have already ran my MC about 10 times with those packs.
              • Make-a-Wake
                FE Rules!
                • 6057
                It could cause a major problem right off the bat or it could abuse one batt that it will eventually give up, bloat, or explode...................
                • DjFlipNautikz
                  • Jan 2012
                  • 70
                  Well I check the temps of the batteries. I usually only do a run of like 8-10 mins and the temp is always about 100* - 110*. Would it be better if I run on battery at a time? Even tho it's a hassle to re tape and stuff.
                  • alvinm
                    • Feb 2012
                    • 77
                    I'm using the Grim 42x55 prop now, will the x640 perform better?
                    • Rob DeAngelis
                      • 296
                      I ran a 5400mah 3s 20c and a 5400mah 2s 20c and had no problems... everything was cold after a w.o.t. run for about 5 mins... and I havent even upgraded cooling...
                      Lakeside entertainer
                      • Rob DeAngelis
                        • 296
                        btw im running the grim 2300kv instead of the regular 1800kv if that makes a difference, idk...
                        • cpgise
                          • 98
                          Is that the ammo motor?
                          • Rob DeAngelis
                            • 296
                            no its the stock AQ motor thats in the UL-1...
                            • Rob DeAngelis
                              • 296
                              btw its a 2030kv... not a 2300 like i said... typo
