Cold weather affecting speed?
  • wakesurfer8
    • Oct 2011
    • 38
    alright i really appreciate the help guys
    • Diesel6401
      Memento Vivere
      • 4203
      Can you post of pic of the items you let the guy at the lhs solder? I don't trust the guy based on his advice. Just wanna make sure he did things correct.
      Sent from my T-Mobile G2 using Tapatalk
      - Diesel's Youtube
      - Diesel's Fleet
      • wakesurfer8
        • Oct 2011
        • 38
        i took a picture but its not letting me upload it...he said that it was good(hold on now, i know what your thinking) and i looked it over carefully and i know that it is good. I know that i am still a pretty new to this but i know that the connections were good and it all works. I even tested it and it works like a charm...if it is necessary, i can tell you what connector is on each wire....
        • Diesel6401
          Memento Vivere
          • 4203
          Standard on batteries: Female on +, male on -
          Standard on esc: Female on -, male on +
          * Make sure the bullets are covered very well by heatshrink.
          There also should not be any jumper between the esc. You should only have 2 power wires coming off the esc, using the bullets eliminates the need for the series jumper.
          - Diesel's Youtube
          - Diesel's Fleet
          • wakesurfer8
            • Oct 2011
            • 38
            so i could just cover up the bullets that wouldnt need to be used.... it wouldnt hurt anything if i kept the jumper in...
            • Diesel6401
              Memento Vivere
              • 4203
              I had a feeling he was going to do that. The jumper adds unnecessary resistance!
              To connect your batteries in the series circuit without the jumper take the + of one battery and connect it to the - of the other battery. The safest way to hook up your setup is to hook 1 battery negative to the esc negative, take the second battery + hook it to the esc + and last of all connect the 2 batteries. That will help reduce the chance of shorting out a battery to itself which is easy to do with bullets.
              - Diesel's Youtube
              - Diesel's Fleet
              • wakesurfer8
                • Oct 2011
                • 38
                alright i see what you mean... i will try that out tomorrow
                • wakesurfer8
                  • Oct 2011
                  • 38
                  what are some good upgrades to make after 5.5mm bullets? ie.. power systems, scuffing, shapening rudder, rounding bottom of rudder, blueprinting the hull-how is this done and is it necessary?
                  • Diesel6401
                    Memento Vivere
                    • 4203
                    The most beneficial and cost effictive options are to blueprint, scuff tune and adjust. Add a good prop like the m445 which I believe you are running and start tuning. That will yield the best results. Slapping new power or more voltage as must beginners do will typically yield poor results or failures. Take your time and do things correctly. Took me a long time and a lot of money to figure that out!
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • wakesurfer8
                      • Oct 2011
                      • 38
                      is it necessary to blueprint the hull on the MC and how exactly would i blueprint it?
                      • Diesel6401
                        Memento Vivere
                        • 4203
                        Anytime you have a mas produced rtr hull blueprinting is never a bad idea. Darin Jordan did a very nice blueprinting write-up in the PB section.
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • wakesurfer8
                          • Oct 2011
                          • 38
                          i cant find it... could you send me a link?
                          • Diesel6401
                            Memento Vivere
                            • 4203
                            Sorry I can't search from the tapatalk app, its in the miss geico section. There maybe a tread called MG Race Prep or something like that.
                            - Diesel's Youtube
                            - Diesel's Fleet
