Adding expanding foam inside hull??
  • 6sHyper
    <<<Surfs up!
    • 597
    Hi guys i have a Motley Crew that i have only ran twice, its in mint condition still, i have a T180 and a 3674 1900kv feigao 9xl copy in it and it runs pretty quick, I have a 4074 leo 2000kv in the mail and i expect it to run mid 50s on 5s. I have seen a few posts about adding expanding foam in the front of the hull?? Can someone please enlighten me on the type of product i should be using to do this as to not bulge the hull? Also i would really prefer to just drill a hole or 2 inside that way i could use a rubber plug to cover it rather than glassing and painting. any suggestions/recomendations?
    a product i could pick up at home depot would be ideal as we have one nearby.
    Thanks
    • 7651
    Is there a Industrial Plastics there?They would carry the two-part closed cell foam.I have noticed some sray cans with blue foam on the job sites lately.They should be closed cell and probably available at Home Depot or a construction supplier.
    • 6sHyper
      <<<Surfs up!
      • 597
      ya we have an industrial plastics, so closed cell expanding foam is what i'm after?
        • 7651
        Apparently the Great Stuff is open cell and will absorb moisture.So yes closed cell is what to ask for.I've been kicking the idea around myself for my boats.
        • Chilli
          • 3067
          Here is the good stuff.
          Wholesale/retail sales of composite and fiberglass materials, including epoxy, adhesives, carbon fibers, urethane foam, urethane casting rubbers
          Mike Chirillo
          www.capitolrcmodelboats.com
          • slapahondn
            • Dec 2009
            • 70
            Make sure you get the 2 pound foam the 4 lb will make your boat too heavy.
            • egneg
              • 4664
              I have used great stuff for window/door jams - just add it a bit at a time.
              IMPBA 20481S D-12
              • slapahondn
                • Dec 2009
                • 70
                The problem with great stuff foam is that it's an open cell foam and will absorb water over time. The 2 part foam is closed cell and is impervious to water.
