need speed help mc
  • jharper
    • May 2011
    • 30
    need speed help mc
    I run around a decent sized pond in my friends backyard. He's been watching me and now has a traxxas Spartan on the way. I have a motley crew and he's already talking crap. Is there anything I can do to my mc to keep up? Any help please. I hate to neat him in his back yard but, its got to happen. Thanks for your time, jharper
  • kookie_guy
    • 897
    welcome, don't be lazy, browse the appropriate forum.
    http://forums.offshoreelectrics.com/...shless-Q-amp-A
    • jharper
      • May 2011
      • 30
      Thanks
      • bigemike
        • Jul 2011
        • 13
        try a m445 prop or a 42x55 prop the part number for the 42x55 grim racer is in your book for your boat. Then if you want to get crazy you can add and external bec to the boat like a castle 10amp and remove the red wire going into the recierver from the speedo, then you should safely be able to run 5s. And dont worry even in stock form he might get you on the straights with 6s but in the turns you will eat him alive. the doesn't really hold a candle in terms of hull design and laying down the power, not to mention you have a faster motor. Also if you want to upgrade more add the motor from the ul-1 to it. Hope that helps ask more questions about the paticular mods and I am sure we can get you going. Just watch the temps on everything, if things start going above 130, you might start needing some cooling.
        Also if you read the race prep thread in this forum there is alot of good advice
        • jharper
          • May 2011
          • 30
          Great. Thanks a lot for your time bigemike. I will try the prop first and grab a few grim packs. Have a good one and I will update. When his comes I will post a vid. New to this so I appreciate your patience and advice I sure need it haha
          • bigemike
            • Jul 2011
            • 13
            I would get the hobbycity tunigy packs much better price equal or better performance
            also swith motor connectors to 5mm bulletts from preferably castle creations
            and you can switch the batteries to ec5 connectors to handle all the horsepower
            • bigemike
              • Jul 2011
              • 13
              http://www.hobbyking.com/hobbyking/s...dProduct=16194
              those packs are awesome great power
              • jharper
                • May 2011
                • 30
                Thanks for the link. Will 2 14.8's run parallel be too much weight? I have 4 packs but was worried about weight. Venom 5000 50c 100c burst. Maybe too much heat. If so no biggie I will grab 4 of those you sent. Don't wanna smoke it
                • bigemike
                  • Jul 2011
                  • 13
                  i am not sure about the weight, but you could try it, it might be slower but runtimes would be awesome. but if you had it over propped you could fry stuff running those big boys down. just use good common sense, sounds like you are trying to do everything right.
                  • Grimracer
                    • 656
                    I would not change a thing except the prop.. it will hold its own aganst the spartin!
                    Grim
                    • jharper
                      • May 2011
                      • 30
                      • jharper
                        • May 2011
                        • 30
                        The 42x55 sounds like a winner. Thanks and I will let you guys know how it shakes out. We have 4 buoys 250 ft straight and about 100 ft on each end. I guess you could call it a liquid indy haha.
                        • jharper
                          • May 2011
                          • 30
                          Oops newbie double posted. Good job
                          • kookie_guy
                            • 897
                            Just because your pack is CAPABLE of a 250A discharge (5000mah x 50c/1000) does not mean that it will actually go that high. The packs don't push out the amps, they supply the amps the ESC pulls. Same with the ESC, it does not push out 60A (or whatever it's rated at), it's supplies the amps the motor pulls. The amount of amps the motor pulls is dictated by the amount of load you put on it (ie size of the prop, or overall weight it has to push with that prop).
                            So if your motor tries pulling more than the ESC can provide, pop goes the ESC. If your ESC tries pulling more than your packs are rated for, they will swell or pop.
                            As long as you are not adding a significant amount of weight with those packs, I would say run those, they will stay cooler.
                            • jharper
                              • May 2011
                              • 30
                              Thank you. I will run them and temp after. They are from my SC8e. If they work out great if not I will snag a few of those bigemike recommended. Thanks all for your patience and advise.
