If I stick with the stock esc and only run 4s what would be the best upgrade in the motor department I was thinking the 2600kv AQ motor any help would be great
Good upgrade motor
Tags: None
I stuck with the 1800kv and put a seaking 180 in and run 5s with either an x440 or x445 440 more stable 445 is insane fast. For what its worth, I used the stock ESC on 5s with no issues till i got the T180. I just added a BEC an unplugged the red wire.Aeromarine Challenger,Warehouse hobbies Man O War, Traxxas Blast Rescue Rig, AQ UL-1 Yellow, BE REVO,T-Maxx, Vorza, Baja5B, and the latest addition Baja5T,
Wife's gunna keel mee!
Sorry I really didnt answer your question....but my point is that the motor is pretty decent already..Aeromarine Challenger,Warehouse hobbies Man O War, Traxxas Blast Rescue Rig, AQ UL-1 Yellow, BE REVO,T-Maxx, Vorza, Baja5B, and the latest addition Baja5T,
2600 kv on 4s =
Try the UL -1 motor, 2030 KV if you feel you need to change it.Grand River Marine Modellers
The best bang for the buck is a better prop than the stocker. If you haven't run the stock motor on a different prop yet, you're really missing out. With just a prop change, you're going to be in the 45-50mph range with the stock electronics. Changing to a higher kv motor of the same can size isn't going to help you do any better than that.
I am running a 440/3 on it right now but I'm not sure its the best. The temps are all low under 100 I just want to make it as fast as I can on 4sBrappp
I've run a M545 on mine and like it, but my cell voltage sags a bit much for my liking. I've heard of others running M445's with great results though. You really should try out a couple of different props before thinking about changing the motor out though.
Im looking into a Leopard 4074 2150 KV with seaking 180 and grim racer 4S's. I have heard this is a great set up for maximizing speed and keeping temps low. I also heard it will get the boat into the 60's. Let me know if anyone has worked with a similair setup.
Mine has the 4074 2200kv and swordfish 200, thunder power 5000 45c 4s2p and I'm not in the 60's yet with any current prop. I don't run the boat really loose but it's still flighty right at 55mph. I ran the 4074 in my FE30 with a seaking 180 right at 63mph though so it's possible. Things do get pretty warm during my 2 minute runs.
