6 pole
  • dascoadams
    • Feb 2011
    • 134
    6 pole
    What's the best timing to run a ul-1s with a 120a turnigy esc 6 pole (stock motor) 2030kv on 4s 4000 lipos
    Running stock prop...and L38x55
    Choices....0..3.75...7.5...11.25...15...18.75...22 .5...26.25
    Thanks
  • longballlumber
    • 3417
    Timing on the stock UL-1 controller is 10 degrees. I would bet the 11.25 setting would be fine. Make sure you check temps for the first few runs...
    Later,
    Mike
    • dascoadams
      • Feb 2011
      • 134
      Later,
      Mike
      The turnigy esc is set at 15 deg. from the factory..ant I've been running it on that.. seems to run cool I wonder if it will even run warm on 11.25....how much slower will it be on that timing
        It depends on the load on the motor. You won't see a dramatic difference with normal props. I've run my FE-30 on 10 and 15 degrees and most times see no difference in speed or heat.
