Help whit aquacraft set up
  • carnalito
    • 99
    I have a aquacraft sv 27 motor whit 60a esc, l try a pro boat resiver and transmitter that l have extra from another project and l cant make it work right it only works if l push the trigger forward, tried the buttons on top of the transmitter and make run backwards l have pull the trigger to make it stop do you know what l doing wrong??
    Help please.
  • Brushless01
    • Apr 2010
    • 487
    The sv doesnt have reverse
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
    • carnalito
      • 99
      l know lt will go forward if l push the trigger but l cant set it up so when l pull the trigger go forward, tried to change the two buttons in top of the transmitter but it only make it worse it will go by it self anr if l pull or push the trigger it will stop.
      Any suggestions??
      The transmitter and receiver are from a blackjack
      • Brushless01
        • Apr 2010
        • 487
        Maybe that radio isnt compatible with the sv27 esc and motor ??
        • scoota
          FE DOWN UNDER
          • Dec 2008
          • 409
          Try the thottle trim adjustment or try the throttle reverse switch on the transmitter ..does the tranmitter have to be calibrated with the ESC ???
          UL1- 1515 castle/neu / 240 swordfish
          SV27- with UL1 running gear
          33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
