ABC prop suggestions please.. Help..
    • 9438
    I just need to ask this here one last time.
    ABC prop recommendations for:
    P-lmt Mono- DF33 Dynamite Blue stock 1500kv
    P-lmt Mono- DF33 Dynamite Blue stock 2000Kv
    P-lmt Mono- DF33 Dynamite Blue 2000kv Huff Wind --- All on a Flycolor 150 esc with Stumpfab Cooler and 10K MAH
    P-Mono DF Cyberstorm Neu 1521 1.5D Castle XL2 ESC - 10K Mah
    P Rigger RSX310 Huff rewound 2200kv Leopard 4092, SF220 pro ESC 4S1P 6500mah
    Thanks in advance!!
  • TRUCKPULL
    • 2971
    P-lmt Mono- DF33 Dynamite Blue stock 1500kv - 1914
    P-lmt Mono- DF33 Dynamite Blue stock 2000Kv -start with a 1714
    P-lmt Mono- DF33 Dynamite Blue 2000kv Huff Wind --- All on a Flycolor 150 esc with Stumpfab Cooler and 10K MAH - start with a 1814
    P-Mono DF Cyberstorm Neu 1521 1.5D Castle XL2 ESC - 10K Mah -1915
    Thanks in advance!!
    • HTVboats
      • 802
      Larry has the mono's covered very well. As for the hydro with similar power and rpm's I would try ABC 1817-1819 and 1817/3. For heat racing I like the Dr Props 645/3. These have been my go to's
      Mic
      Mic Halbrehder
      IMPBA 8656
      NAMBA 1414
      • TRUCKPULL
        • 2971
        Mic
        Mic
        His rigger motor is a 4092 Leopard 2200 Kv rewound by AMP Daddy. Full "P" class. NOT limited.
        Larry
        • HTVboats
          • 802
          I understand what he has. I don't want to recommend things that might go up in flames. Start conservative add pitch and diameter as you test. I have a Keps P with a 36X84 TP 2050 that obviously is less power but a similar size hull and those props work well. Also I run a modified JAE 33 (longer) with a 4074 1750 on 6S our Q/Limited class that uses these props. After an 1819 the jump to 1900 series props offers less usable props. The 1817/3 with the 3rd blade will carry more weight and is stiffer than a 1819. Dr Props makes a 648/3 but needs cup bent in to make it work and not just slip.
          A 310 with a 4092 is in my mind overpowered for normal running. My Keps on 6S has run high 18's on timing lights. Way overpowered for Q but perfect for P just slower. Just trying to give sound advice with my hydro experiences.
          Mic
          Mic Halbrehder
          IMPBA 8656
          NAMBA 1414
          • TRUCKPULL
            • 2971
            Mic
            Sorry I was concentrating on your comment of "hydro with similar power and rpm's" thinking that you meant Limited class power.
            Larry
            • HTVboats
              • 802
              No big deal we all need to just share what we learn.
              Mic
              Mic Halbrehder
              IMPBA 8656
              NAMBA 1414
                • 9438
                Thank you for this Mic. I also have a 3684 Scorpion 2200kv 1Y motor I could try. It's actually in the boat but after re-reading Mike L's build thread on the 310, I thought the scorpion wold be under powered???
                Do you think I should try the Scorpion motor first with say the 1817 I have on hand?
                Thank you Larry. This thread is a bookmark for me to reference. Hopefully I can get out this weekend to test out the Rigger, P Ltd mono and a couple small fun boats.
                • HTVboats
                  • 802
                  Ray, motor is in the boat. all you need is a prop, easy test and you may be pleasantly surprised. It is hard sometimes to recommend for FE guys as there are racers and some just ZOOM ZOOMERS. I have seen some sucess with Octura 545 and 645's.
                  Mic
                  Mic Halbrehder
                  IMPBA 8656
                  NAMBA 1414
                    • 9438
                    Excellent, thank you! Could I try a 45mm TFL 1450 prop? I bought it from Zippits. They said it was a 1450 but advertised as 45mm. When I measure it it's about 46mm, very thin. I can upload a pic if it helps??
                    • HTVboats
                      • 802
                      I have seen those work well too. My thoughts on boats is try every prop you can get your hands on. Some you thought wouldn't work might surprise you. Doesn't work pull it off no harm no foul. That said there is a range. 2317 might not work well. Or stuff that 4092 in and blow it off at 80mph and see how well your boat is built.
                      Mic-
                      Mic Halbrehder
                      IMPBA 8656
                      NAMBA 1414
                        • 9438
                        Lol, that's great, thanks again. I've got my work cut out for me.
                        BTW, it's built pretty tough.
