Best prop balancer
  • Jesse J
    scale FE enthusiast
    • 7241
    Best prop balancer
    I have been using an old (15 yrs) airplane prop balancer, but know there has to be better.
    What do the pros use?
    "Look good doin' it"
    See the fleet
  • mappo
    • Feb 2010
    • 487
    I’ve seen some reviews on this one Du-Bro Tru-Spin Prop Balancer DB499, I just ordered one myself
    Do you know what the biggest problem with the world is?
    That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
    • NativePaul
      Greased Weasel
      • 2764
      I'm not a pro, but I use one of the generic cheap chinese boat prop balancers that can be found with a dozen different band names, modded with a piece of microscope slide glass over the magnets which freed it up a lot ( i think the neodymium magnets in these are too soft to be ideal for use, maybe copper then nickle plated rather than copper then chrome). I have used a few balancers and this is the best of them.
      Neither of the 2 pros I know use static balancers at all, both ballance dynamically, 1 spinning the prop on a shaft in his well trained fingers, and 1 spinning the prop mechanically at 10,000 rpm with sensors. Both get a better result than I believe is possible with any static ballancer.
      As an aside, while it is nice to have a well ballance vibration free driveline when you give it a blip of throttle to check things are working in the pits, I am not sure how much it matters or if it even matters at all on the water when we are driving hundreds if not thousands of Watts through the bottom blade when the top blade is basically doing nothing. That is something I don't hear being discussed and I would like to hear others opinions on it.
      • dasboata
        • Dec 2010
        • 3152
        text sent don't go checking my props now LOL
        • longballlumber
          • 3119
          This is great advice from Paul. The glass keeps from tearing up the magnets. It's also important to have the points on the shaft be center ground on each end. It keeps a consistent centerline down the shaft being used to balance.
          • longballlumber
            • 3119
            These are very nice!
            • longballlumber
              • 3119
              I can't argue the hydro dynamics involved in this system. It's well above my cranium level. I can tell you with a great deal of confidence a properly sharpened and balanced propeller will provide better performance and handling than a prop out of the bag all other things being equal.
              • dasboata
                • Dec 2010
                • 3152
                curious to see the microscope glass you use , almost impossible to get every prop balanced perfectly
                • Mike W
                  • May 2018
                  • 348
                  Originally posted by longballlumber View Post
                  I'll never use anything else. Had to rebalance my whole collection.
                  Otto RC Marine
                    • 9438
                    Andy Kunz used to use a strobe light to help balance a prop. How it's done is a mystery to me???
                    • Jesse J
                      scale FE enthusiast
                      • 7241
                      Thanks Chris
                      See the fleet
                      • Jesse J
                        scale FE enthusiast
                        • 7241
                        Strobe and molding putty to get each blade identical.. that is overkill to me, since the prop is in and out of the water so much.
                        See the fleet
                        • jim82
                          • Jan 2013
                          • 1358
                          Get the this one. Badasss
                          • Moonie
                            • Jan 2014
                            • 342
                            Jew balancers are the most accurate we can use for our model props.
                            Gold Spilo
                            • Jesse J
                              scale FE enthusiast
                              • 7241
                              ??? What are Jew balancers?
                              See the fleet
