prop suggestions for newbie
  • mrd72
    • Oct 2021
    • 70
    hello, I have a tfl 56? genesis w/dual neu 1000kv motors, 200 ztw escs running 8s to each side (2x 4s 5000mah) I notice the electronics gets a little hot after 4-5min?s of running. I dont race boat, i just use it in my local lake. itheres octoba x457 props on there now. Can you recommend if these are a good prop with my setup. i dont run constant full throttle. thanks, mike
  • koen
    • Mar 2020
    • 366
    just go to a bit smaller prop so that you can always go flat-out ,esc and motor don't like partial power(and get hot)however a runtime of 4min is not bad
    • dasboata
      • Dec 2010
      • 3152
      Im going to give you something a bit smaller in ABC you will be smiling !!
      • mrd72
        • Oct 2021
        • 70
        looking forward to them! thanks
        • mrd72
          • Oct 2021
          • 70
          took your advice, ran the boat full throttle 90% of time, motors and esc actually ran a little cooler @120F but my batterie?s got up to 140-165F and one got swollen. Ran them to about 3.5V?s after 4 minutes time. the battery that got swollen has IR readings about 1-2 ohms per cell, dont know if it?s damaged though. the other batteries have about anywhere from 1-4 ohms per cell but look fine even though they got hot too. Wow, theres a lot of trail and error trying to get everything balanced to work effectively. Im looking for Dasboata for my new props and go from there
          • Peter A
            • 1498
            You should not take your batteries below 80% discharge. They got hot and puffed because you over discharged them. If you want longer runtimes you will need to parallel in another set or use bigger capacity batteries.
              • 7990
              A resting voltage of 3.5 volts means the cells are completely drained, no usable voltage left. What is the LVC setting on the ESCs? A correct setting should have prevented this. As above, they are probably permanently damaged.
              • eehess81
                • Jun 2021
                • 158
                Get rid of that battery, it is permanently damaged and could possibly cause a fire.
