T mono props??
  • tjj atx
    • Mar 2018
    • 109
    T mono props??
    I'm putting a T mono together and looking for some help on prop choices. I already have an ABC 2714-15-65(3) CPL (68.58mm) and was hoping it might work.
    Set up
    46" Y6 mono w/ flooded stuffing tube
    Leopard 56110 780kv
    Swordfish 300X
    10,000mah of 10s
    If I'm way off with that prop any suggestions would be appreciated.
  • RaceMechaniX
    • 3024
    For Mono's I recommend starting off with Octura X series. The low pitch ratio is more forgiving than higher pitch ratio's and they are low lift. I would try a X455/3, X457/3, X460/3 or X460.
    Prather props also tend to work well. P250, P255, P260.
    The 2714 you mentioned may be a little large to start off with. That's a typical gas prop, but you will be spinning 30-40% more RPM than a Zenoah on 10S.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • tjj atx
      • Mar 2018
      • 109
      I thought that 2714 would be a bit much and yes I ran that prop on gas in this hull. My other FE monos do run much better with the Octura X series props. Why mess with a good thing, I'll go with X series. Thanks for the help.
      • Peter A
        • 1624
        I'm running a 45" mono with TP5670 650 kv and seaking 130 HV esc on 10s. With an ABC 2314/3 it is running at 90kph and amp draw is reasonable using <4000 mah for a heat race. It's enough to keep up with and beat larger gassers. The race water can be nasty!
        • tjj atx
          • Mar 2018
          • 109
          I'm going to have to run a little faster than that to keep up with the T monos and T cat in my club. Course speeds in the 65mph(104kph)+ range and the club record straight line run is 73.6mph(118.4kph) which won't stand for long knowing this group. I'll be happy with low 60s, gotta finish to win it!
          • tbonemcniel
            • Sep 2020
            • 294
            Travis?
            • tjj atx
              • Mar 2018
              • 109
              Originally posted by tbonemcniel View Post
              Travis?
              Yes sir, whats up Tbone
              • tbonemcniel
                • Sep 2020
                • 294
                Oh ya know, keeping up on boat stuff while I'm at work. Your thread caught my eye, because of my current T Mono build. Then that last post talking about the speed record, I said, "hmm, that sounds familiar. That's HOTMBC." Then I remembered you mentioning a T Mono build yourself, looked at the screen name, and made an educated guess.
                I think it'll be fun with our lowly TP/Lepoard/Swordfish boats keeping up with those Lehner/Schulze boats. We're at a disadvantage already, but I'm certain you can do it, and I think I stand a chance.
                • tjj atx
                  • Mar 2018
                  • 109
                  I'm trying to build a drivable boat, if you can actually finish a race in T mono you've gotta great chance at winning. Those sniper 45's are crazy!! What kv did you go with?
                  • tbonemcniel
                    • Sep 2020
                    • 294
                    970kv
                    • tjj atx
                      • Mar 2018
                      • 109
                      970kv
                      Lets continue this on FB.
