I am running a 4814 two bold If I go to a 4518 3 bld is that smaller? I am running a 2030 KV UL1 motor. I want the same speed as the two blade but I want the stability of the three blade
2bld to 3bld Q
You change about everything, number of blades, Diameter and Pitch.
The result will be a surprise and very much depending on the boat.
The 6,7% of change in diameter will not compensate the 28,5% Pitch-Change.
If both pitch-ratings are true (which often is not the case
) the 4518 will try to make the boat go much faster but this is simple rule of proportion. Whether the boat can handle the speed is a different story.
Ray I sent you the money via PayPal . I know you sent me an email but I didn?t get it. My email is garyaaandmargy@yahoo.com
Ok shorthand acronyms, I didn't get the translation manual. In that diameter and pitch range I would look into a DR. Props 645/3
Mic
Mic Halbrehder
IMPBA 8656
NAMBA 1414
