Prop recommendations for neu 2230
  • BlakeT
    • Jan 2020
    • 536
    I?m building a 60? bonzi Apache with a neu 2230 725kv motor on 10s or 12s whichever is better for the motor. Any info on props or setups from similar builds would be greatly appreciated.
  • Ken Haines
    Racer
    • Jul 2007
    • 673
    What Kv ?
    TenShock Brushless / Pro Marine
    INSANE Boats / Rico Racing/ Castle Creations
    2023, 2024 NAMBA & 2018 IMPBA FE High Points "National Champion"
    • BlakeT
      • Jan 2020
      • 536
      Whoops, can’t beleive I forgot that. It’s 1y 725kv
      • Ken Haines
        Racer
        • Jul 2007
        • 673
        I run currently that motor on a 48" Assault on 10s 2p / 12,000mah (The NAMBA Legal limit).
        Pretty versatle motor which can be run on up to an Octura X-472. I have used a Prather 275
        when running it in my 45" AC Laser which worked well. My bigger mono's do seem to like some lift.
        • BlakeT
          • Jan 2020
          • 536
          Wow! I was figuring an x465 but never thought about going that big for a prop. Thank you for the input that is very useful, what speeds are you seeing in those monos? I would imagine they put up some stout numbers. I am shooting for 60-65 with this boat. Also if you don’t mind me asking what esc you are running on it, thanks!
          • Ken Haines
            Racer
            • Jul 2007
            • 673
            Certainly work up to that X472. An X467 would be a good starting point.
            I do run a Schulze 40.300 to allow for this higher amp draw. Also a 60" hull
            probably will have more drag, but possibly higher boyancey which could offset the size.
            • BlakeT
              • Jan 2020
              • 536
              Yes I will start smaller and work up to it, thank you for all the info!
              • Ken Haines
                Racer
                • Jul 2007
                • 673
                I would also recommend using a straight medium stiff 1/4" flex shaft with no step on that large of a boat.
                Good luck with the build !!
