Counter Rotation Props Configuration
  • Insaniac
    • 425
    I am putting together a FighterCat Cheetah and was wondering how to configure the rotation of the counter-rotating props? Should the LR prop be on the outside shaft or the inside shaft?
    We run a clockwise course at our pond if that makes a difference.
    Support US hobby suppliers
    • 4335
    My twin Cheetah runs great with inward spinning props.
    • Panther6834
      • Apr 2020
      • 708
      Same here with my ProMarine Skater X2...port side runs clockwise, and starboard side runs counterclockwise.
      • dasboata
        • Dec 2010
        • 3152
        most boats I see run the props turning to the inside they say inside for speed turning out side for handling !!1
        • Panther6834
          • Apr 2020
          • 708
          Chris, so you'd say 'inward' for racing, and 'outward' for SAW? Just curious, myself, as I'm also still learning.
          • Insaniac
            • 425
            I checked the "Big Boys" over at Mercury Racing and they run them turning inward; CW on the port side and CCW on the starboard side.
            Thanks!
            • dasboata
              • Dec 2010
              • 3152
              inside for SAW
              • Panther6834
                • Apr 2020
                • 708
                inside for SAW
                Got ya ..so, inside for racing & SAW.
                  • 4335
                  My experience has been it depends on both the hull and if you're after straight line stability or turning performance. What the full scale boats do doesn't really apply to us, the hydrodynamics are completely different... primarily because our props aren't scale sized.
                  • ArnoudRC
                    • Oct 2020
                    • 50
                    On a twin you just change the leads for changing the rotation direction right?
                    Verzonden vanaf mijn iPhone met Tapatalk
                      • 4335
                      No. To change the direction of a motor, you just swap any two wires, but then you MUST swap your flex cables and props to the opposite sides. If you don't swap your cables, you'll spin them in the wrong direction, causing them to unwind and potentially cause catastrophic damage.
                      • ArnoudRC
                        • Oct 2020
                        • 50
                        Tx. I?m aware of the rotation direction for the flexshafts. They differ. For the motor direction I was curious.
                        • dasboata
                          • Dec 2010
                          • 3152
                          mis leading and damaging information on this conversation
                          • ArnoudRC
                            • Oct 2020
                            • 50
                            Was not the intention. Following the advice to run two props inward on a rc cat, I just wanted to be sure that (with the right flexshafts and props cw/ccw) I change motor direction by swapping the leads. Am preparing myself for a twin cat for next season, that?s why I ask. Is that damaging? Sorry.
                            • Insaniac
                              • 425
                              Assuming that you have flex shafts that are wound in opposite directions, another way to reverse the motor direction is to program the ESC rotation (CW or CCW).
                              I have my motor leads color-coded to keep the same wiring configuration in case I have to remove an ESC or motor.
