3 blade 1.4 pitch prop
  • meangenesracing
    • 1332
    looking for a prop a little bigger than an octra 440/3 I see the next size up in the octra line is 447/3 and I'm sure is to big for my p hydro whiplash. I use the 447/3 on my 1/8 scale with great results. Any and all help would be appreciated thanks
    • 4340
    ABC makes a 1616, which is essentially a 40.6mm diameter, 1.6 pitch ratio. Nothing from Octura in that size, unless you had a 447/3 cut way down, but those are hard to come by to begin with.
    • koen
      • Mar 2020
      • 367
      Look at Modelbaucentre lorenz they have a ABC 1715 3blade and a lot of ABC props
      • dasboata
        • Dec 2010
        • 3972
        I have 1614/15/60/3 a bit bigger Jeano
        • dasboata
          • Dec 2010
          • 3972
          you better double check that ?
          • meangenesracing
            • 1332
            Chris, whats the diameter of that prop? Is it a 1.4 or 1.6 pitch? How much, $ thanks
            • dasboata
              • Dec 2010
              • 3972
              1.6 diameter 1.4 pitch ratio $70 plus the shipping
              • meangenesracing
                • 1332
                My calculations is only .03" bigger than what I have the octra x440/3 don't think that would make a very big difference. What you think?
                • koen
                  • Mar 2020
                  • 367
                  modelbaucenterlorenz.de in Berlin
                    • 4340
                    the 40.6mm diameter and same pitch ratio are not the numbers that matter here. The ABC props have more rake on the blades than the Octura props, which equates to more thrust. It also changes other characteristics like the amount of lift they produce at the transom of the hull.
                    • meangenesracing
                      • 1332
                      Thanks for the information I'm not that familiar with ABC props and props in general
                      • meangenesracing
                        • 1332
                        Chris, I pm'ed you on prop payment
