I need a few ABC props
  • eXoNerated
    • Jun 2020
    • 233
    Hi Does anyone have some raw ABC 1918's they would part with? I know I could call Jim but I want them like right now. I want to run my scale in oval trim this weekend and see how far my calculations are from reality.
    Thanks,
    Hubert
  • T.S.Davis
    • 6228
    Do he even make a 1918? Seems like something he would but I haven't seen that.
    Noisy person
    • jim82
      • Jan 2013
      • 1358
      He makes a 1918-10-50 is that the one you after?
      • eXoNerated
        • Jun 2020
        • 233
        Hi Terry and Jim,
        Is the "50" the BAR and "10" the rake? I have a motor I tuned that I think will be a good oval motor. The calculator seems to like the 1918. But I'm not positively sure of which port of that prop it likes. Maybe I should get all the available s and test each one.
        In a performance hydro with 10s lipo @ 9800 mah and a castle 240. Prop wizard selected an ABC 1918 as the most efficient prop for the setup.
        Resultant:
        28,221 rpm
        141 amps
        4,955.78 watts Pin
        4,728.58 watts Pout
        run time 4.15 minutes
        est speed 79.20 mph or 127.46 Km/h
        Eff. 95.42%
        The efficiency doesn't begin to drop off till 284 amperes surely the beginning of the end @ 10.5 kW. Here are the motors constants and parameters
        Rm .oo5 ohms
        Kv 824
        Io 3.27 amps @22.5 volts including radial fan load.
        Weight 448.8 grams
        12 slot 10 poles
        What a long day....
        • dasboata
          • Dec 2010
          • 3152
          Thanks,
          Hubert
          I have a new one in stock I only sell finished props PM me if interested thanks
          • eXoNerated
            • Jun 2020
            • 233
            Hello Chris,
            Is that right for your name? Do you offer the aging service for the ABC beCu ? A few of the props i want done with a special LE backside detail . Those ill; likely do myself but I would possibly interested in a hardening service. Do you do stainless as well?
            Thanks ,
            Hubert
            • dasboata
              • Dec 2010
              • 3152
              Hello Chris,
              Thanks ,
              Hubert
              Ya guys with charts and grafts scare me I'm going to pass,, but LMK if you want that 1918
              • eXoNerated
                • Jun 2020
                • 233
                No thank you I dont want a prepared prop at this time. Andy Brown or myself does that. Im looking for raw 1918's
                Regards
                Hubert
                • jim82
                  • Jan 2013
                  • 1358
                  Post over on intlwaters.com Mark or Walt may have them
                  • eXoNerated
                    • Jun 2020
                    • 233
                    What is the direct line to ABC and Jim S. ? I cannot find it in my contacts.
                    Thanks
                    Hubert
                    • dasboata
                      • Dec 2010
                      • 3152
                      Thanks
                      Hubert
                      Ill sell you the raw 1918 10/50 $30 shipped
