Prop fitment issue on Sonicwake
  • danaf
    • May 2020
    • 1
    All, I purchased a CNC 40mm 3 blade 3/16 bore prop for my Sonicwake. Is it normal for this prop to be a very tight fit on the shaft? In fact, to even get it to start to slide on I've had to carefully ream the bore. The orginal prop slid right off.
    • 4340
    I have some props that fit tighter than others. Sometimes its just the dog teeth at the end of the bore.
    • jim82
      • Jan 2013
      • 1358
      It'll be fine long as you didn't ream it out much. How does it fit now?
      • dasboata
        • Dec 2010
        • 3972
        I come across this once in a while in my business , I glue & wrap some sandpaper around a appropriate size rod and put it in the drill works great
