Prop size?
  • Zzoom
    • May 2019
    • 45
    Prop size?
    New to boats, have a cheaper China abs boat I've been upgrading and completely redid everything from original setup. It's a 800mm with a 150 amp flycolor esc, turningy1650kv 70amp 2600 watt, 3674 motor running a 3/16 flex driven drive setup on 6s. What's a good prop size to start with?
  • Zzoom
    • May 2019
    • 45
    A 45 mm wouldn't be too much or could I go bigger
    • Peter A
      • 1622
      You should start smaller, 40-42 mm and test and check and work your way up in prop size.
        Cat or mono? Racing or sport running? Exactly what batteries? What is the length of the pond?
        An x440 would probably be quite safe as long as the boat is properly trimmed and not run for more than 2 minutes (use a timer). But we really need more info.
        • Zzoom
          • May 2019
          • 45
          Sport running, vector 80 mono, 2 3s 3000-30c in series.
          I have multiple lakes of good size and a very wide, straight canal long enough to run out of signal
          • Zzoom
            • May 2019
            • 45
            I had just got it all done with an sss 3674 1300kv motor running a 40mm prop. Maiden run was gonna tape hatch after a quick cooling check and make sure no water was getting in through the drive. She ran perfect, ballanced but a little slow but safe at full speed n then bam she is stopped at an instant n sunk. Nose up but all submerged, lost hatch. There was a 5 gallon bucket under the water and I found it. Motor is smoking after I dried it out and tested it .everything else is good luckily because everything was brand new (esc, motor and power hd 20 kg digital servo) including complete everhaul of drive system upgrades
            • Zzoom
              • May 2019
              • 45
              I'll try the 40 I got n then go up from there. Never got to get results from the sss motor since it lasted all of 30 seconds. Most of that was trimming and making sure she was pissing
              • Zzoom
                • May 2019
                • 45
                Still waiting on the cheaper motor and new hatch so needed some new props and wasn't sure how big I can go with the new motor
                • Alfa Spirit
                  • 2183
                  Run Graupner K serie propeller to find the best diameter.
                  • Zzoom
                    • May 2019
                    • 45
                    Ok thanks, are they a cheaper prop I could get a few different sizes and then get a better quality
                    • Zzoom
                      • May 2019
                      • 45
                      I have a 38 and a 40 gonna grab a 42 and a 45
                      Thanks again everyone, hopefully I'll have better luck this go around
                      • Alfa Spirit
                        • 2183
                        I buy some CNC Propellers here, 12 €uros each :
                        • Alfa Spirit
                          • 2183
                          Graupner K carbon propellers are available here at OSE :
                          https://www.offshoreelectrics.com/pr...s+Carbon+Props
                          • Zzoom
                            • May 2019
                            • 45
                            Nice setup, I had previously ordered the cheaper ose brand 38 and 40 I'll try these as well for testing
                            • Zzoom
                              • May 2019
                              • 45
                              How long does shipping take from AliExpress
