Flexshaft is stuck won't come out but motor coupler spins putting trying to put on new coupler
Anyone have problems getting the flex shaft out of the proboat recoil 26
Tags: None
the shafts get crushed by over tightening and bulge on the other side of the Ferrell inside the collect is usually what happens if you have enough room to take apart the collect you can try to spread the fingers on the Ferrell to pull the shaft out more then likely your shaft is shot alsoOriginally posted by MARKBRENNAN View PostFlexshaft is stuck won't come out but motor coupler spins putting trying to put on new coupler
What is the Ferrell?Originally posted by dasboata View Postthe shafts get crushed by over tightening and bulge on the other side of the Ferrell inside the collect is usually what happens if you have enough room to take apart the collect you can try to spread the fingers on the Ferrell to pull the shaft out more then likely your shaft is shot also
I think he meant to say ferrule, but he really means collet. The collet is the part which contracts and squeezes the cable. A soft cable and/or over-tightening can deform the cable making it difficult to remove.
This is a collet:Attached FilesERROR 403 - This is not the page you are looking for
